Fuel Injector Replacement Issue
Old Feb 22, 2010 | 06:25 AM
Bobs4Runner's Avatar
I replaced one of my injectors yesterday, put everything back together and started it up. It fired up nice, sounded strong...but...
I noticed one of the original injectors is leaking from the top were it meets the fuel rail. I was just able to lift the drivers side and swap the injector out. At this point now that I have to pull every part off again, should I just replace all the o-rings and bushing? Or just reseat them?
These are the original bushings and o-rings, they were put into a new engine (not installed by me).
Thanks
Bob
Old Feb 22, 2010 | 06:44 AM
mt_goat's Avatar
I'd replace them all. Also the fuel rail crush washers are one time use items. Read this: http://www.ncttora.com/fsm/1996/SIL/.../inje/inst.pdf
Don't play around with fuel leaks.
BTW it would be a good idea to have the other 5 injectors cleaned, and the whole set of injectors flow tested
Old Feb 22, 2010 | 07:37 AM
Where the hell are the fuel rail crush washers and how many are there?
Old Feb 22, 2010 | 07:52 AM
mt_goat's Avatar
The FSM calls them gaskets, there are 4 of them, 1 on each side of both banjo connections. Really they just look like washers, but they are a soft metal that seals as you torque the bolt.
Old Feb 22, 2010 | 08:01 AM
Are they the 4 black round things that go between the fuel rail and motor? Guess I'll have to make a list of whats to get at Toyota.
Old Feb 22, 2010 | 08:30 AM
mt_goat's Avatar
No, here are 2 of them. There might be as many as 6, it just depends on how many of the banjo bolts you loosen up.
Old Feb 22, 2010 | 08:47 AM
camo31_10.50's Avatar
this is some good info....i did not know these were one-time use only..thanks Dale!!!
Old Feb 22, 2010 | 08:51 AM
mt_goat's Avatar
I'm sure there will be someone chime in now and say they have never replaced one and never had a problem. But as long as you are at the part counter anyway and they are cheap.
Old Feb 22, 2010 | 10:34 AM
Cbohl51's Avatar
I'd agree. Spend the .75 cents and stay safe. Fuel leaks are nothing to play around with!
Old Feb 22, 2010 | 03:15 PM
$0.75 I wish...dealer is killin me for these things.
Old Feb 22, 2010 | 10:04 PM
Ken's Avatar
Ken
Agreed with replacing the O-rings.
If you can afford the down-time, send the injectors off to be deep-cleaned: http://www.witchhunter.com/
Old Feb 22, 2010 | 10:09 PM
Tracey98277's Avatar
i saw this and knew i had too...
i used my old ones and didn't have a problem.
i'm sure goat is plotting my demise now
lol.
Old Feb 23, 2010 | 05:25 AM
OK, Just got a call from the dealer to let me know all the o-rings and gromets (insulators) are in:
Here's what I got: (8) O-Rings, (6) Upper Insulators and (6) Lower Insulators.....ready for this...$66 TOTAL!!!!!!
Any place else I can get these?
Old Feb 23, 2010 | 05:58 AM
Philbert's Avatar
Maybe LC Engineering?
Old Feb 23, 2010 | 06:27 AM
mt_goat's Avatar
lol.
Old Feb 27, 2010 | 04:47 AM
So after 2 trys (damn over torquing) I finally got the injectors installed. Runs great now. Thanks to this site for all your help. Its alot easier then I thought.
Bob
Old Apr 10, 2010 | 09:39 AM
takeitoutgetitdirty's Avatar
For further preference, I got all my seals (o-rings, gromments, and seals) for 5.00 thats all of them that I needed From NAPA auto
Old Apr 10, 2010 | 12:11 PM
liquidtouch's Avatar
i was gunna say try local auto store.
bigjstang
Jun 2, 2025 03:56 PM
Yont283
Sep 23, 2022 08:06 PM
Regency
20
Jan 3, 2020 07:43 PM
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
