Rear break line no fluid
Old Feb 26, 2010 | 07:44 AM
kawicowboy's Avatar
I just replaced the rear driver side axle seal on a 02 Tacoma and also the brake line that goes from the wheel cylinder to a connector on the rear diff, its only 20inches long, After I put the line in I tried to bleed it but nothing came out, I opened the res, I pumped the brakes, I also drove around and still nothing. The brakes feel fine and the parking brake works. What could be the problem.
Old Feb 26, 2010 | 08:00 AM
j2img's Avatar
is the truck up in the air on a lift or jack stands? try bleeding it with the truck on the ground to keep the LSPV out of the equation.
smthwsn357
May 1, 2024 07:28 AM
87turboPA
Jul 12, 2015 07:49 AM
Poncho0206
Jul 10, 2015 06:21 PM
87turboPA
Jul 9, 2015 05:58 AM
skoti89
Jul 6, 2015 07:45 PM
