Sparkplug Wire Question, Cracked plastic
Old Feb 24, 2010 | 06:15 PM
Toyoda22's Avatar
Exclamation Sparkplug Wire Question, Cracked plastic
I was putting in some NGKs on my 2.7 and i saw that on my last cylinder that the connecting tube that goes down into the well and snaps onto the sparkplug, Well that piece has a crack going all the way down the side of the plastic outside of it. IS that causing a voltage drain? could it arc out there and not be transferring all of its power to my plug?
will giving it a good wrap in electrical tape fix it, or will it be too hot in there for the tape?
anyone know how to find a cheap replacement if necessary?
Old Feb 24, 2010 | 06:34 PM
Elton's Avatar
get a new set from sparkplugs.com use this code YTECH10 save 10%
Old Feb 24, 2010 | 07:17 PM
crolison's Avatar
ditto, get some new plugs
Old Feb 24, 2010 | 07:38 PM
TheDurk's Avatar
Old tractor mechanic trick is to run the engine inside a dark barn. If you see blue light anywhere, something is leaking voltage. Not recommended to do this in a garage, for (I hope) obvious reasons.
Old Feb 24, 2010 | 08:01 PM
SkidPalace's Avatar
Cool. I had a '94 VW Jetta VR6 that had lousy coil packs which radiated little electric arcs all over the outside of the packs (and caused misfires) when they got even a little wet. I'd bet those looked awesome in the dark.
Old Feb 25, 2010 | 01:06 PM
Toyoda22's Avatar
so i definitely need new wires?
Doug4320
Mar 24, 2018 10:11 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
A2theK
Jul 12, 2015 10:46 AM
Coreyr384
Jul 10, 2015 11:13 AM
horunner1x
Jul 10, 2015 06:33 AM
