PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 [161] 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. I need a motor!!
  2. SAWS installation difficulties
  3. 4.88's and 32's??
  4. Why are Tacoma Tie Rods Cheaper?
  5. help with a vibration problem
  6. Door Trim Scratches
  7. '96 4runner 3.4 hard start
  8. 4th Gen 4R... Fuel Injector cleaner.
  9. New here
  10. *Heads Up* LSC 10I - 2001 4runner
  11. Is the Hayden 1679 tranny cooler too much!?
  12. im selling my 98 S/C tacoma
  13. Symptoms of bad front O2 Sensor??
  14. Where to buy...
  15. Who was maiking the cool yotatech.com sticker???
  16. What causes Code 25 (Lean)?
  17. Options to look for on a new Tacoma
  18. ok so what does everyone use for...
  19. Injector issues...
  20. Wet Okole 1st impression
  21. 2nd Gen Suspension
  22. Clutch fluid ?'s
  23. Exide XCD Batteries??
  24. Locked rear axle price?
  25. safe to do a tranny drain on an old transmission?
  26. Seattle/Bellevue Clutch Shop?
  27. Hello! New to board, long time listener, first time caller.
  28. Which Brush Guard
  29. I wanted to kill this guy...
  30. TRD supercharged and gasoline
  31. Gas mileage sucks on my 2.7 Pre Runner
  32. 3ap exhaust tip (ebay)
  33. Where can I get a Hayden tranny cooler!?
  34. 2000 Prerunner Questions
  35. Are my brakes bad?
  36. 3rd Gen Tranny Question
  37. O2 Update + Whole new problem...
  38. 3.0 V6 Headers !!!!!!
  39. toyota robot
  40. Got me a digicam . . . pics of the rig
  41. Bumpstops revisited....just talked to downey
  42. What size spacers on 01 prerunner
  43. quick question
  44. Bucket Seats - 1990 needed
  45. Tail Lights
  46. Fuel injector cleaning prices?
  47. attn: 4th gens with revtek..
  48. SEARCHED: Need to know where to get valve spring compressor
  49. Factory 4runner Limited Woodgrain question
  50. using anARB compressor for air
  51. fuel mods at altitude???
  52. seat wear idea
  53. Gorilla Wheel Locks--What Size??
  54. got my sliders
  55. heater core replacement in first gen
  56. 95 Limited nearly identical to mine for sale
  57. Am I a chick because of This?
  58. Finally pics of my new Runner
  59. I tore my steering rack boots
  60. 4 Gen wheel / brake rust
  61. 4th Gen, remove my factory roof rack cross bars?
  62. New tacoma Pre-Runner Rear Bumper
  63. 4Runner came with 31x10.5x15, can I use a slightly less wide metric sizes safely?
  64. See, I'm not a web wheeler
  65. Cargo box mock up.
  66. Just my luck...could it be an HG failure?
  67. Remote Controlled Spotlights
  68. Aisin hubs. Which types?
  69. Torque Converter Operation Explained
  70. '90 4runner Blown Head Gasket
  71. Got new boots for my truck. *** pics ***
  72. Here are some Yakima Towers for 2nd Gen's
  73. New Offroad Vid review
  74. test drove 1999
  75. modular intake tube
  76. Starting issues with Truck
  77. 4X4 coils
  78. K&N FIPK Systems...are they a joke or do they work?
  79. TRD of Borla Cat Back..which is better?
  80. Coolant Leakage, !$@&*
  81. Hydro-Locking
  82. Almost gave in to the Tacoma Temptation today
  83. Im Selling my 90 4 runner
  84. what's the deal with bushwacker?
  85. 3.0 Fuel Filter Replacement ?'s
  86. body shake
  87. 305/70/16 MT/R's installed
  88. My first stump pull with the Runner...
  89. 85 diesel alternator trouble
  90. Tacoma tranny codes/id
  91. Lubing SAW Balls
  92. drove my neighbors truck tonight
  93. seats
  94. V-6 Parts vs. 4 Cyl. on 1988 4x4? (Differential & brakes!)
  95. Double-Check My Order (Wheels & Tires)
  96. Pulled valve cover off 22R, engine is siezed????
  97. 2005 V8 4Runner jumps to 270hp
  98. i hate some mechanics!!!!!!!!!!!
  99. 87 4runner motor mounts.....
  100. Replacement Antennae for 2nd Gen besides Taco Whip??
  101. CB Antenna - Hood Channel Mounts
  102. hey guys new member here got a question??
  103. Lifting an 87
  104. Anybody familiar with DUAL headunits?
  105. MALL Crawlers
  106. STEERING SHAKES OVER BUMPS on a 04
  107. 2nd Gen?
  108. tire size
  109. E-Locker ECU, where is it located?
  110. 4 link versus leaf spring SAS
  111. ARP studs
  112. 3.0 is back together and has a nasty shriek...
  113. 87 4runner idles up and overheats
  114. weber 32/36
  115. 95 4Runner headlight/ parking wire location
  116. The dreaded 3VZE crossover
  117. Problem with Hella500 Install
  118. Revving your eng while in neutral
  119. Next mod
  120. NEED Quick help findng ECC
  121. PIcs of clear corners on 01 taco for the interested
  122. It costs how much?!
  123. 3.4L swap tachometer Q
  124. 99 4runner LTD, hesitates when hitting the gas
  125. Engine Braking vs. Economy
  126. Scooped hoods cheap
  127. mini truck~lowered to small lift
  128. Lift for 2001 Prerunner
  129. Clutch Pedal & Body Lift
  130. Grinding when turning
  131. Dfw Wat
  132. Is this bad (steering)?
  133. Replacing the steering seal on a 2nd gen...
  134. Oil return path for 3VZE?
  135. how long can i drive with water in the diffs?
  136. What do ya think?
  137. Cornfeds tomorrow
  138. Attn: All Gear Heads!!!!
  139. Rear Heater Core Leaking
  140. compliments
  141. ACT 6 puck clutch noise
  142. gears/tires
  143. Transmission input bearing whine
  144. Got my 3rds
  145. Billy going bigger...37's and another 3"'s
  146. anyone here in the military
  147. finished my light bulb conversion
  148. '00 4Runner ARB locker gearing
  149. Oversize valves?
  150. anyone have pics of winch mount Runners
  151. Replacing Fuel Filter in 94 Runner
  152. Home Made Toyotas....
  153. mounting aluminum truck box
  154. Trying to Mount winch by saterday (need help!!)
  155. 98 4Runner Antenna Mast replacement
  156. center console 99-02
  157. rear diff bolt stripped!!
  158. Paint Job Woes
  159. WTF! I can't believe this!
  160. Engine Swap?
  161. 4x4 2005 Tacoma?
  162. what muffler should i get
  163. Clutch Master or Slave?
  164. Can't get screw on distributor out! HELP! (tried lots of things)
  165. Should I lift my 03 Tundra?
  166. Fuel Damper??
  167. Lights...video
  168. homemade SAS/rear lift?
  169. switch box cover
  170. ptcfactoryoutlet.com deals for yotatech members!
  171. Has anyone ever seen these?
  172. Engine code ???
  173. I need 2002 modification help!
  174. Finally getting a rear tire carrier
  175. Alternator and Lights
  176. Rear axle seal replacement tips 2nd gen wanted
  177. Stealership does it again!!
  178. This sucks in rush hour traffic!
  179. well, i broke a cv axle
  180. Got a question on changing the colour of my instrument panel
  181. Fuel grade question for 04 4runner
  182. Do you need to find stuff for toyota trucks?
  183. wing window
  184. Soundproofing your rig - New question
  185. manual hubs?
  186. Cam doesn't line up - Can someone help?
  187. Replacing my Engine Wire Harness ?
  188. Clay Bar uses
  189. RockWare Bumper Installed
  190. Power Brake Booster
  191. Question for LEE
  192. Squeaky bed?
  193. High lift
  194. Installing a NGP Firestik 2' CB antenna
  195. just talked to toyota about headgasket recall...
  196. Tacoma: What size ball drop for towing?
  197. Interior Rhino Lining???
  198. Celica Seats into a Taco
  199. 2000 4Runner Paint System
  200. Transmission housing bolts?
  201. Gen 4 Euro glass headlight capsule & H4 bulb?
  202. I see the light!
  203. New Toyo's and wheels
  204. 4th Gen, rear light mod, feasibility ?!?
  205. OEM/Cole Hersee light rocker switch
  206. newbie lookin to get a rig
  207. Valve adjustment on 3.0L V6.
  208. 4th gen tires--what's biggest without lift?
  209. Toyota symbol removal
  210. Some Pics of My 4Runner
  211. Built a Cargobox with Pics
  212. Well, One more tranny q
  213. Speakers
  214. Rear window motor problems
  215. Removing Cat
  216. MR2 airbox swap-performance mod???
  217. Smoker, vent, stupid small triangle window
  218. 4Th Gen Thule Rack Setup
  219. Window motor question...
  220. Westin Safari Bar for 03 Runner
  221. Wua-wua-wua sound, help!!
  222. Part number help 2nd gen
  223. Tell about the advantages of adding a locker
  224. What can I build with this stuff????
  225. simple o2 sensor ?
  226. Do these body mounts look right?
  227. full-time 4wd?
  228. Went to Hawaii last week
  229. Simple Question, Plese Help!
  230. euro tailights
  231. Electrical and power gurus...need answers
  232. tripp lite
  233. Speedhut no longer lists the 4Runner Gauges
  234. Headliner Removal ?
  235. Question about selling my 4Runner...
  236. Steering shaft joint protector necessary?
  237. Gas Pedal on 04 Taco needs adjustment
  238. Steering wheel free play
  239. PLEASE HELP... need advice on rebuild???
  240. Where Can I Get A Connector For This?
  241. Odd 22R no start problem?
  242. Cosmo Racing
  243. is ors 3.4 conversion kit worth it?
  244. 4Runner lodging (not dial-up friendly?)
  245. Don't plugs need to be oily if bad rings?
  246. IFS Aisin hubs on ebay
  247. whats the best/easiest/cheapest lift
  248. Fridge write-up w/pics
  249. Still having problems:
  250. clean engine inside and out
