Installing a NGP Firestik 2' CB antenna
Old Mar 10, 2004 | 09:38 AM
calrockx's Avatar
i'm planning on installing my cobra 75 wx st CB with the help of Bob this weekend, but we need some advice on how to install this type of antenna.
could you guys who are running a non ground plane antenna explain your installation? as in the principle behind it and any tips we should know. that sure would help out a lot. thanks...
also, i'm thinking i want to install it on the fender using one of those hood mounts - will it work if it's on the passenger side, near the FM antenna? i won't have the FM antenna up while using the cb. i know this may not be the optimal place but I only need it to work on the trails, and i think that's good enough for such close proximity. yeah i could put it on the TJM or roof rack, but....i don't want to.
Old Mar 10, 2004 | 09:56 AM
waskillywabbit's Avatar
Talking Jacksonpt
Jackson has an antenna like that. Check his website or ask him.
I hope this helps! I have got to get my CB installed soon as well so post your pics and tips!
Old Mar 10, 2004 | 10:41 AM
shazaam's Avatar
uuummm hate to say this. But if you want an easy set up, that your only going to use while off roading is to attach it to the TJM.
I have one of those spring mounts that screws right in, and then the antenna screws right into that. Otherwise the antenna just sits in the back. The coax cable runs straight through the grill, and along the left quarter panel through a hole in the lower fire wall, and then under the dash, and cross over to the passenger side. I placed the mounting bracket for the cb on the side of the shifter box, and everything looks nice and clean. Takes about 40 min to hook up.
The only thing I need to fix, is I need to remove the plastic between the sring mount and the TJM bumper to get a better ground.
This way you save yourself from drilling holes in your truck. good luck
Old Mar 10, 2004 | 11:00 AM
jacksonpt's Avatar
Senior Member
What exactly do you want to know? There's not much to it. You should have gotten a NGP kit (antenna, coax, and mounting hardware). The coax is designed for a NGP antenna, so all you do is loop the connector over the bolt, then add your washers and whatever other hardware you need, and snug everything down. Whatever you do DON'T CUT THE COAX. There's something about it that if you cut it you'll ruin the coax and not get any decent reception.
If you want to know the technical side of things about how NGP works, you'll have to ask someone else. It's just plug-and-play for me.
Old Mar 10, 2004 | 11:40 AM
Talking 2' NGP antenna
What antenna you got? Work well. I got to pick one up before May 14.
Old Mar 10, 2004 | 11:47 AM
shazaam's Avatar
4' firestick II .. got it from mike at extremeoff road.
I think there was a guy on here that was selling mounting brackets for the ARB bumper for like $20 .. scroll through and see if you can fnd it.
nvdesertrunner
May 11, 2020 08:18 PM
DeathCougar
Apr 1, 2018 11:29 PM
mussy01
Dec 13, 2016 08:20 PM
punks_is_4x4
Aug 21, 2015 01:35 PM
TDonkey
Jul 26, 2015 10:14 AM
