What size spacers on 01 prerunner
Old Mar 14, 2004 | 09:28 PM
ElwayLite's Avatar
I was looking at the cornfed spacers and was curious if you guys knew what the right size would be to level my taco up to do away with the hunkered down front stance?
thanks
Old Mar 15, 2004 | 04:36 AM
Dr. Zhivago's Avatar
Away
A 1-1.5" spacer would be good, with the 1.5" probably being the better choice.
Hope this helps.
G
Old Mar 15, 2004 | 12:30 PM
ElwayLite's Avatar
Thanks. With the spring problems over time with the spacer, is that only if you wheel or is it from driving in general?
thanks
Old Mar 16, 2004 | 05:37 AM
Away
The problems with spring sag are inherent with any spring. Some are more prone to failure than others, depending on a lot of factors. One of those factors is fatigue, which all springs are bound to do over time. If the springs on which the spacers are mounted are prone to early fatigue to begin with, then the spacer will only exacerbate the problem and not necessarily be the root cause of it.
Having said that, I think that wheeling the truck would accelerate spring sag more rapidly versus street driving.
Here's a thread you might find interesting: https://www.yotatech.com/forums/showthread.php?t=28835
Peace.
G
Edited for spelling.
Old Mar 16, 2004 | 06:46 PM
ElwayLite's Avatar
thanks! gonna add em to my list of items I want to do to my truck, I think itll look a little better leveled out with some more height on the front.
Old Mar 17, 2004 | 05:54 AM
Away
Here is another place you might find interesting: http://www.allprooffroad.com/tacoma.html
Scroll down and look for the Tacoma 1" Front Coil Spacers. These particular spacers sit outside the coil pack, above the top spring seat. They do not pre-load the spring and do not change the ride characteristics at all like a spacer that is inside the coil pack will do. Plus, they're inexpensive. You will still need a spring compressor to install them.
Peace.
G
Old Mar 17, 2004 | 07:29 AM
ElwayLite's Avatar
Thanks!
4x4YOTA
Aug 23, 2016 09:08 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
4runnerFireman
Sep 29, 2015 06:24 AM
crash813
Sep 27, 2015 07:15 AM
Gravel Maker
RuffStuff
Sep 8, 2015 05:46 AM
