- 2003 4Runner wheel question.
- What is real? (re: fuel capacity)
- fuel injector cap?
- Gotta laugh!!!
- Manual Hub Bolts
- Time to Think about 2004 D-Cab Tundra
- Heater Core replacement...Any clues, tricks, tips?
- tal and hadas grill gaurd
- Factory 3-disc CD changer cleaning - E-02 Error
- Slipping clutch
- just checking, 4runner & tacoma cv's the same
- Best Place to buy, shocks and spring questions
- Trying to avoid Rollover for 4runner
- Downey Parts Source
- N00b greetings and a ?
- 1/4 mile track run
- Custom Truck Shades Cee Bailey's
- License Plate Holder
- I/O thermometer
- PowerTrax Lock Right vs. Detroit EZ?
- 2.7 liter ISR mod...
- Mod day goes great until...
- Hiccup at WOT?
- Got MUD?!?
- Ignition timing adjustment
- greddy exhaust????
- Rancho RS9000's
- Any Interest in an Early 22RE Engine Block/Head?
- 96-98 Recall
- Has anyone swapped Stock 4runner seats with another vehicles?
- where can i get jdm hilux parts?
- rear end sag
- legal exhaust limit
- Knock sensor=bad
- Recipe for a shiny rig
- "Idle Air Control" valve questions
- SAW's and OME
- Once again... a body lift question
- custom 2001 Tacoma bumper pics
- Rollup Tonneau Covers
- If you can put a buick 3.8 in a Toyota...
- Leak at 3rd member- 94 V6
- stearing box leak
- Day Time Running lights.
- finally some pictures..
- 22re a/c idle
- 4 Runner Stock Clock Question
- Suspension lift questions, yes another one
- Should I stay or should I go?; pt 2
- Door lock programming
- Shaving emblems?
- Grand Cherokee vs. Runner??
- 22r--->2.7???
- My New 26in Rims Are On!!!!
- Idling/Throttle Body Problems
- Rear diff breather extension complete
- ECU Connector Descriptions?
- 96-98 and 99-02 front bumpers are innerchangable
- K&N Air filter question
- Finally got rid of the street tires....
- new to this board
- '03 4Runner Maintenance and Performance
- How many miles so far on 2003
- My ride and my trail recon vehicle
- 3rd gen rear axle seal
- !Help! need to put on skid plate gah! must wheel!
- Bored today Look What I did !!
- Couple of Mods today!
- Takeoffs anyone?
- Redline MT-90
- PIAA 520's in black or chrome - pic of light bar!
- Differential
- Asking for Pics of the 2.7L
- winch cable snapping vid
- Blob on fuel rail/delivery pipe
- OEM filters
- Low Temp t-stat for a 3VZE
- Wierd noise...HELP!!!!
- Wow me first post!
- Landcruiser, Prado, Hilux Diesel Turbo
- Found a 92 Hilux Surf today...
- 3rd gen sliders?
- Hilux Surf
- 2dr OR 4dr?
- Ect Function
- Has anyone ever broke 5 wheel studs??
- Woooohoooooo!!!!!
- Dammit... Now I need a rear wheel bearing
- 4runner lift????
- get a winch!!
- There's no such thing as a stupid question.....
- ISR mod for a Tacoma?
- Much Thanks!
- Tire size question
- The beast is clean
- Fabtech 6'' suspension
- bad day!!!!!!!
- Help this guy out? Update!
- Is this a good deal?
- HELP ! ! ! (torsion bar replacement problem)
- If I get a supercharger...
- Disabling rear window function on 03 4runner keyless entry
- 03 4Runner Chirping Sound - Squeeky Belts
- rear bumbstops in 2nd gen
- My complaints on the '03
- EGR and Air valve
- dash lights
- SC Pulley
- Roof Racks
- Hella H4 replacement headlights and PIAA Super Whites
- 4th Gen VSC - Can it be turned off?
- Power loss
- Free ISR mod part! WOOHOO!!!
- Tacoma rear seats
- Best Lift Kit?
- best lift to add 35' tires
- Newby 4Runner questions
- Strange Observations re Spiral Cell battery (Champion XLT DT34)
- Extended Cab Tacoma Guys HELP!!
- Clutch causing "surging"?
- Good Deal?
- Need your opinion fast!!
- What could be wrong with my panhard rod?
- Door panel removal. HELP!!
- Window Motor or Switch???
- Engine swap question
- 03 exhaust
- Coolant Smell
- power steering pump
- Bulb Sizes Question
- IRS mod
- Toyota dealer parts sale (Renton WA)
- Any brakes experts HELP!
- 03 4Runner AVG MPG Computer Display - Is it accurate?
- 4th Gen Runner bumper guard...
- 94 pickup on 38's?
- Is my exhaust supposed to be humid?
- need help picking ome's
- What is my bolt pattern and max tire size on 03 4runner?
- '01 4Runner SR5 Stereo Question
- Need to find a Vacuum line
- WSave my baby, or buy a new one???
- You know what I like about Toyota trucks?
- How exactly to mount winch...
- Grille Removal?
- Finally pic's of my truck
- Poll: 4th gen pic up top of forum??
- Should I Line-X or powdercoat my sliders?
- Can you stand another ISR Mod alt
- 4 low
- Rear Oil Seal Leak??
- Panhard Rod drop Bracket
- will the 99 limeted molding work on my 96??
- Aftermarket stuff for '03 Runners ?
- Winch Trouble!
- Anybody Have a Tornado Fuel Saver?
- 4 Wheeling in Iceland?
- Cobra CB Radio & Power Inverter Group Buy
- how do u keep sand out of airbox?
- whats a highlander???
- I' a believer in Redline...
- 22r stalling problem...need help!
- Free carfax report
- What have you picked up for free?
- Any suspension lift kits for 2003 yet?
- Fresh Tech
- Best Alternative to Hella Micro DE's ???
- DRL + accessory lights
- Installing Floor Lights
- best "lunchbox" locker?
- Weak 3rd gen rear springs
- what do you think?
- Light truck, do I need 9k lb winch or 6k lb?
- Bulbs, bulbs, too many bulbs.
- Help! Front hub removal...
- Goofy Keychain Mod.
- Air Lift 1000 problems..
- No more sag in the back
- Another fog light question!
- Bad Bearings Causing Rattle??
- more 03 damage
- Has anyone installed XM Radio...
- 91 toyota suspension questions
- rear lift springs
- New Fj--think Toyota Will Build It?
- Super 50RWHP exhaust mod!
- A sucker is born every minute
- Chrome Package Tailpipe Tip (Pic)
- any truck trails in fairfeild county, ct?
- Chrome Package Tail Lamp Covers (Pic)
- On the contrary, what's the BEST thing you've done to your Toyota?
- Swithing 2wd shifter for a 4wd one
- 3vz rblt shortblock on Ebay . . .
- mp3's
- The UN messed with my wiring !!
- Best Lift *Newbie
- ISR Mod - Test Data Revealed! (See attachment)
- Level 10 Valve Body HydroSystem
- Should I Supercharge?
- Whinning Noise
- Help!!!
- New Tundra...
- Taco oil question
- just got my first truck....what should i do?
- I'll ask it again...2wd offroad??
- Same frame on 4Runner and Tacoma?
- Check these headers out
- high swr reading
- Oil level between changes..
- Altimeter
- 4 runner engine swap?
- TRD thermostat Part ##
- The most stupid thing that you've done to your Toyota
- 5 * shine!
- IFS/Transfer Case skid plate update
- 99-02 front bumper on a 96-98
- New injectors and plugs?
- what does this mean
- The Truth Revealed
- 2nd gen. Auto to 5spd swap????
- On-board drinking water other than TJM?
- Looking for a new truck?
- Three wheel motion... =P
- High pitched noise from brakes on 03'
- 650HP tundra
- Vancouver, Lower Mainland
- Lug Nuts
- front end on '96 tacoma 4x4 (Again)
- A/T P light?
- Interior Bike Rack
- 36k Preventive Maint
- My Runner is leaving....
- Busy week...mudflaps, tranny cooler, tire gauges
- Squeaky rear axle---Possible causes?
- Did I buy [poopy] tires? 285/75/16
- Roof rack removal?
- How are these rotors?
- ARB bumper on E-bay
- "Type R" Extended Diff Breather mod---or how I got 50 more HP from a breather!
- whining in 3rd and 5th
- Car Wash or Hand Wash especially 2003 4R owners
- Mrs. Schaefer is getting a 1993-1997 FJ-80! What do I need to know?
- Aisin Hubs - Question
- What do I need for cross country + wheeling?
- blowing running lights fuse
- Multiple questions :)
- Update on page... (sway-bar stuff)
- Buying a 91 4runner what should I look for
- New Mods...PICS!! LCD's and Thermometer
- Im Driving Across the Country...Wheelin anyone?Potential MOVIE !!!
