Oil level between changes..
Old Apr 21, 2003 | 04:27 PM
az4x4runner's Avatar
Question Oil level between changes..
I'm just curious, but I assume it's not so normal for the oil level on the dipstick to go down some by the end of the 3000 miles between oil changes..? Does anyones here go down some, if so how much? Mine is near the bottom of the cross hatched section, but it's due for a change too.. (probably tomorrow). I just wondered, since I just put about 1000 miles on it this weekend.. (mostly 70mph and up).
Thanks a lot,
-Bryan
Old Apr 21, 2003 | 04:38 PM
CTB's Avatar
CTB
Mine goes down from the top of the hashed section to the middle of it (approximately), but that was when I had a slight oil leak. I have run a couple of bottles of Bearin' Seal through it and hopefully that has helped some. However, I don't think I am burning any...just a slight leak.
Old Apr 21, 2003 | 05:20 PM
lunatic14r's Avatar
i read some where that toyota say that 1 to 2 qt of oil consuption between oil changes is normal
Old Apr 21, 2003 | 05:38 PM
CTB's Avatar
CTB
That still seems unreasonable to me. Just doesn't seem right.
Old Apr 21, 2003 | 05:40 PM
Well, I know the manual says it's normal for it to consume some, and mines been worked hard this last 3000 miles, so I'm not gonna worry (i see no leaks, and pretty sure it doesnt burn it).. hmm is there anyw way I can check and see if tis burning oil?
Old Apr 21, 2003 | 07:20 PM
Sucellus's Avatar
Don't know much about your engine, but I know that in 5,000 miles I don't lose ANY oil. And I run a lightweight (mobil 1 5-30) and have done so for the entire life of the car.....Perhaps that's why?....Just my $.02.
Check your plugs. You can tell if your burning oil from them.
Old Apr 21, 2003 | 10:06 PM
Arsrmk's Avatar
My oil level seems to drop a little when I drive it hard(pull trailer, climb mountain passes,etc) Must be burning a little off under the high rpms and load I guess. Otherwise it seems to stay at the full line between changes. An indication of burning oil might be slighty dark/black exhaust or if your tailpipe is black could also indicate burning oil.
Old Apr 22, 2003 | 08:06 AM
rabidbeaverbaby's Avatar
i lose about a pint every 1000 miles....i had a mechanic check it out and he said that he couldn't find a leak and that it was normal for an 11 year old truck.........:beaver:
Old Apr 22, 2003 | 11:44 AM
slowyota's Avatar
I usually have to add anywhere from 1/2 quart to a full quart at the 2,000 mile mark. I don't have any leaks either. Just burns it I'm assuming. I'm not to worried though, 140,000+ miles, 8 years old, who cares if the only maintenance you have is adding oil every 2000 miles.
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
yourrealdad
Jul 29, 2015 11:08 AM
calderp
Jul 27, 2015 09:58 AM
Jeffreynmandy
Jul 18, 2015 08:26 AM
akaphilly
Jul 9, 2015 02:18 PM
