94 pickup on 38's?
Old Apr 23, 2003 | 08:33 PM
yotaman94's Avatar
94 pickup on 38's?
If i put a 4 inch suspension and 3 inch body could i fit 37 or 38's. Anyone do this on a pickup? any pics would be great. Thanks
dpiza2002@yahoo.com
Old Apr 23, 2003 | 09:00 PM
DrtRunner's Avatar
I've seen 38 x 15.50s on 10" wide rims fit with that much lift.
Its HUUUUGGE !!!!
Old Apr 23, 2003 | 09:38 PM
Hawaiian4R's Avatar
I've seen a few here with 40's. HUGE!!!!!!!!!!!!!!
Old Apr 24, 2003 | 11:33 AM
mangoango's Avatar
I think you could clear 35's with that much lift. To go 36's or bigger, you'd probably need to go higher - crank up the torsion bars and add-a-leafs in the back. Without more lift you'll probably rub the tires really bad when you turn.
-mangoango
Old Apr 24, 2003 | 11:38 AM
Flygtenstein's Avatar
On IFS?
I would have to be thinking not.
I rub 33's on the idler arm.
Massive fender trimming, little backspacing, rare steering and no wheeling.
Old Apr 24, 2003 | 08:48 PM
4 the Hard Way's Avatar
Re: 94 pickup on 38's?
dpiza2002@yahoo.com
It "CAN" be done, but I wouldn't. Any kind of 4WD will kill the cv's. On my '94 PU in the front I am running the 4" Trailmaster with the Rockstomper IFS travel kit, and in the rear 56" long AOR Poly-Eye springs and shackles...combine that with a 2" body lift and I clear 35's on a 15x10 wheel with no problem. No rubbing off road. But I could "fit" 37's...buy the first rock would tear the fenders off. So, if you don't plan on really going off road, sure, 38's could fit with some t-bar cranking and some more help in the rear like an extended shackle.
Here's a pic of my '94....
Good luck!
Greg
MY WEBSITE
PS. I used to run 39.5's on my '88 4Runner when it was on IFS way back when....
sandyota
Feb 4, 2021 11:16 AM
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
rondogracing
Jul 14, 2015 07:00 PM
