K&N Air filter question
Old Apr 26, 2003 | 03:42 PM
obxfishn's Avatar
I remember reading something a while back about taking out the EFI fuse to reset something in the computer with the air mixture when you install a K&N air filter. What is the purpose for this procedure? If this is the case do you pull the fuse out with the vehicle running, with it off, or do you pull the fuse and start the vehicle? Does anyone have any inside on the proper procedure for doing this. I have a 02 Taco 4x4 2.7L. Thanks in advance.
Old Apr 26, 2003 | 04:02 PM
Paul H.'s Avatar
If all you did was put the drop-in in then you do not need to reset the computer. If you did want to reset the computer then you pull the fuse with the engine off and leave it out for about 20 minutes. Hope this helps.
Old Apr 26, 2003 | 06:53 PM
Hawaiian4R's Avatar
What is the purpose of re-setting the computer?? I got the K&N FIPK installed, do I need to to that?
Old Apr 26, 2003 | 06:59 PM
Victor's Avatar
It will make the computer adapt to the new changes.
Old Apr 27, 2003 | 12:51 AM
Hawaiian4R's Avatar
Well I just pulled my fuse for about a half hour and put it back in, will it make my truck run better?
Old Apr 27, 2003 | 02:28 AM
UKMyers's Avatar
Did it do anything?
Old Apr 27, 2003 | 02:52 AM
rimpainter.com's Avatar
By resetting the ECU, your truck adjusts quicker to the mod you installed.
Old Apr 27, 2003 | 06:43 PM
Hawaiian4R's Avatar
Oh, okay thanks.
smthwsn357
May 1, 2024 07:28 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
Eggslinger
Jun 8, 2019 03:32 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
ryerye13
Jul 14, 2015 08:27 AM
