91 toyota suspension questions
Old Apr 22, 2003 | 02:56 PM
Question 91 toyota suspension questions
Hello All - I'm a newbie to this forum. I've owned a 91 toyota pickup for the past 8 years and am now looking into upgrading the suspension.
Questions:
I am looking into the Downey Suspension. Where is the best place to purchase? How hard is it to do? Any pros and cons out there?
What should I upgrade when I am doing the suspension? Torsion Bars? Leaf Springs? Shocks? All of above? What else?
Any advice would be helpful. Thanks
Old Apr 22, 2003 | 03:03 PM
Cebby's Avatar
Welcome to the forum.
To answer your question, we need to know more about your rig and how you will use it.
Old Apr 22, 2003 | 03:07 PM
more info
More info would make sense...
91 Toyota Pickup
2wd
30x9.50 tires
3 " body lift
4 banger (love the 22r, 190,000 miles)
Looking for upgrades that are street legal but will improve performance and suspension.
Let me know if more info is necessary.
Old Apr 22, 2003 | 03:12 PM
rimpainter.com's Avatar
I can help you in the performance dept.
Start with I/H/E (Intake, header, exhaust) and then go from there.
If you plan on doing some pre-running, then I would avoid K&N filters.
You should be able to free up some HP by having an exhaust shop make an exhaust for you.
Oh yeah, welcome to the forums. Be sure to use the search function when you can. That will help a lot. There is a ton of knowledable people here.
Old Apr 22, 2003 | 03:14 PM
why no k&n
Why should I avoid K&N?
What other intakes are good for pre-running?
Old Apr 22, 2003 | 03:23 PM
Re: why no k&n
There a couple guys on here with pretty solid data (oil analysis, etc) that point toward K&N filters letting in way too much dirt. The filter of choice seems to be Amsoil or stock. I am not sure if they make one for your truck, but they should.
If I were you, I would get an Amsoil and mod the stock set-up to let in cold air (if you can).
I realize we have two completely different engines, but if you click on some of my mods in my sig, you will see some different ideas. Basically, the idea is to draw in colder air, in a streamlined fashion, while not exceeding the stock fuel capability. On your motor, adding more air involves tweeking the MAFS if I remember right. If you dont know what I am talking about, stick around, there are some guys on here that know the 22R pretty well.
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
Vargntucson
Jul 4, 2015 12:15 PM
