PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 [30] 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. Steep Grades/Offroading + Scangauge II = High Transmission Temps w/ B&M 70264 Cooler
  2. Help! front diff seal Q on 2000 4runner 4wd! Thanks...
  3. Troubles while replacing rack and pinion..
  4. All-Phase Skid plate question
  5. evap monitor not running
  6. Repair or replace Crankshaft Position Sensor 1999 4runner 2.7L
  7. Texas_Ace's Cheap DIY Meth/Water Injection kit Writeup! Get 10hp+ for under $150!
  8. Custom LED switchback turn signals (w/ pics)
  9. Major insurance cost differences between 1999 4runners: 2.7L 2WD and 3.4L 4WD
  10. HP gains from Installing headers?
  11. Wild turn signal issue....
  12. New Carpet
  13. Engine Rebuilds
  14. 02 tacoma 4x4 CV axle ?
  15. Need to tap ignition power source...
  16. Limit Strap Info
  17. manifold back dual exhaust?
  18. Tacoma fuel gauge issue
  19. A340f has gone out again!
  20. Texas_Ace's 2000 Supercharged 4Runner 2 years later Dyno, Meth injection +more power!
  21. What brand replacement alternator 1999 4runner 2.7L?
  22. Tire and spring etc. question
  23. Center Console Ammo Can
  24. Help: Reinstalling Center Console Interior Trim
  25. Spacers and extended studs????
  26. Found a Scooped Hood on CL, what next?
  27. P0420 catalytic converter replacement - Need OEM to get rid of CEL?
  28. 02 Taco - bad lower control arm?
  29. Trd Y pipe ?
  30. Location of Cruise Control ECU on 99 4Runner?
  31. Tacoma power locks actuating by themselves
  32. new shocks - blown in a few days
  33. Casting number location
  34. Swing down rear tire carrier, 3rd gen 4Runner... Do-able?
  35. New Truck! 2000 Tacoma TRD X-Cab
  36. Officially got the ARB bumper and Pioneer Screen on the 4runner!
  37. 300K and getting ready to take a trip what would you guys look at or replace
  38. Not another front end noise.........
  39. Power Steering Fluids.......
  40. Don't ignore your Zerk fittings! (I did)
  41. transmission?
  42. More E-Locker Questions
  43. 4WD issues..
  44. stock tow hitch
  45. help - rear strut broken while traveling 1999 4runner
  46. Removing metal door edge protectors?
  47. 2000 4Runner Rear Brakes Sticking
  48. parts sources for used parts/bumpers etc
  49. Anybody using Fox coilovers?
  50. I have vibration at 60 MPH
  51. Can I drive 90 miles with radiator cap loose or off ?
  52. Tacoma Speedometer Cable Replacement
  53. 180k Refresh
  54. Can I put a 2rz in my 97 4x4 5 speed?
  55. E-Locker factory option in pre-'98 Tacoma??
  56. Stolen Catalytic Converter with unique Problem
  57. Gas milage winter vs summer?
  58. 97 4Runner wont stay running
  59. Front LCA Bump Stops
  60. Stupid Brake Question
  61. Driving across Canada towing a trailer - Overdrive off?
  62. Bushing removal
  63. 175,000 miles...Tranny Cooler or new radiator
  64. Problem Engaging 4WD
  65. trd/bilstein 5100 rubbing?
  66. Rear end popped-now leaks-please helpthe newby
  67. Um, should these two parts be rubbing
  68. Hard Downshifting Issues - Automatic - 2000 4Runner
  69. TPS Change adventure
  70. Autozone guy crossed cables when jumping my 4runner
  71. Flattened camber cam bolt tabs :(
  72. Stepside Flairs
  73. 1998 Taco Alternator Battery or ?
  74. 3rd gen rear diff armor installed
  75. mystery water leak
  76. A340F Inspection Plate
  77. 03 Tacoma Prerunner Column Shift:??
  78. brake shimmy / tight brakes
  79. Camburg 2.5" coilovers vs Sway-A-Way 2.5"s
  80. Kansas City 3rd Gen
  81. A/C not blowing cold
  82. Installed OME 3" lift but still have rake...HELP
  83. 255/85/16 will it fit with ARB 880/906 combo
  84. 99 4runner idle issue
  85. Tranny question
  86. Transmission mount
  87. Westin Safari Bar For 98 but not 96?
  88. 98' 5VZFE PS Flush
  89. 97 2wd v6 4runner master cylinder or brake booster?
  90. Battery Light Question
  91. Runner chewing through wheel bearings
  92. tokico trek master struts - too long? please help
  93. My 4runner on 35's
  94. 2001 4Runner Clearance Question (stock)
  95. Any thoughts on sunroof not opening and now linking (video).
  96. Oxygen Sensor - Code P0136
  97. 2000 4Runner Code 770 - Shift Solenoid Questions
  98. oil cooler hose leak?
  99. Help with rear axle seals and diff breather...
  100. 3rd gen 4runner hub problems
  101. Tacoma Sleeping Platform, Carpet Kit, Camping Setup
  102. Anyone have 3.42 gear ratio?
  103. clutch ?
  104. When the bass line hits...battery, alternator, or bad grounding?
  105. fog light switch help
  106. Failed SMOG, no power to OBD???
  107. 95 taco clutch replacement...need help!
  108. Are Duralast Rotors okay? I need to get them replaced tomorrow.
  109. General Front End Rehab Questions
  110. Knock sound when engaging transmission
  111. Cel code: H02S12
  112. Shrockworks Bumper with a twist
  113. o2 question do the gaskets and bolts come with the sensor?
  114. P1130 help!!!
  115. New Coils from a 06 Tacoma
  116. question about flushing tranny fluid
  117. 3gen 4runner stick shift woodgrain bezel
  118. help. point me to a SF bay area shop that has tuned a 7th injector
  119. Pressure Rising when hot
  120. Tranmission Fluid Change
  121. Transfer case removal?
  122. Harsh ride on my 4runner
  123. TRD Spring Isolaters
  124. Alighnment after Lift?
  125. Wheel jerks on hard braking
  126. 99 runner ...could these 2 issues be related?
  127. 02 4runner transmission downshift
  128. Tacoma Manual Hub Conversion With Factory Parts Complete
  129. Worn Inner Shifter Boot on '98 4runner?
  130. 99 Runner Limited - how to bulb replacement
  131. Parts interchange
  132. Dumb E-locker question
  133. Replacing a TRD FJ anthracite rim
  134. P0302 Misfire Question
  135. are all 95.5-04 ECU Harness Plugs the same?
  136. Do you have photo of your stock air intake?
  137. 4th gen seats into a 3rd gen?
  138. Can someone help with body lift install?
  139. Welding Sliders Help
  140. 1995 tacoma 3.4 4x4 M/t Vin
  141. Brake Self Adjuster problems?
  142. My 4runner sounds like a sprinkler!!!
  143. Water Temp Sensor 3.4
  144. 99 Runner Radiator cap....what brand ?
  145. 97 3.4 Runner with EGR??
  146. Gobi Ladder Finally Installed!
  147. Value rebuilt of 3.4l V6
  148. P0171
  149. 4runner leaking grease from rear right hub
  150. Interior creaking
  151. 1996 4Runner Axle/CV boot questions
  152. overhead ext temp gauge
  153. HELP!! installed 881 / 906 on '99 4runner.. *PICS
  154. 3rd Gen 4runner FAQ
  155. 98 Taco Rear spring question
  156. Another Strawberry Milkshake 1999 4runner
  157. 02 4Runner - single-din aftermarket stereo install question
  158. Rear ABS sensor Good or Bad after trashed rear bearing
  159. How hot can this engine get...
  160. Pop when turning left
  161. Need a part number: clips/groments for fender well plastic trim
  162. barke Booster
  163. HELP!!! Code p0171 96 4 cyl tacoma
  164. Problems after Timing Belt Change
  165. 01' Runner Missing. HELP!!!
  166. Very loud howling from rear wheel 98 4runner limited
  167. Tranny Differences
  168. 4runner beeps
  169. 5VZ-FE vs 3VZ-FE oil weights
  170. Spare Tire - holding Bracket
  171. Oil in intake, need some input
  172. 2002 Tacoma Running Lights and Fog Lights?
  173. Cracked Headlight Housing
  174. Automatic Transmission Filter Change Help..
  175. Anyone know the ID of the ratiator hose?
  176. P1700 code help
  177. Erratic RPM at highway (70mph) speeds. Hard downshift when coming/leaving stop.
  178. 2.7L exhaust
  179. P0171 CEL w/ strange rpm linked noise
  180. Are you satisfied with your OME 881/906 setup?
  181. Regearing problems!!
  182. 97 4Runner Rear Axle Inner Seal Leak
  183. Open tube on intake of 02 4runner v6
  184. Coils rubbing inside of spindle?
  185. Tacoma Single Cab: Bench seat interchange
  186. How good is 140PSI compression for a 2.7L 4Runner?
  187. 1999 Tranny Fluid Change Question
  188. 3rd gen 4runner Scoop Hood (more) questions
  189. Sway in my 98 Tacoma
  190. High angle cv shaft's
  191. opinions on my 04 tacoma trd
  192. Grinding/Vibration coming from tranny area.
  193. Mice made a nest in my fan blower, need help getting everything apart!
  194. Headlight Polish or Replacement?
  195. e brake handle won't fully DISengage
  196. raspy thrush 2.5"
  197. Need pics of underside of 99 4runner
  198. Possibility of swapping rear differential with E-Locker rear...
  199. question about installing spool in front diff.
  200. CA Cat to 49 state
  201. Which way do these wires go back in on the fuel pump?
  202. Fan pulley/Bracket
  203. Driver's door lock won't work when hot out
  204. 215K miles...now what
  205. Weird problem with 2000 lmtd.
  206. high gear RPM's 99 runner
  207. CEL P0135 (O2 sensor) code.....
  208. Question about machining a head
  209. clicking noise!
  210. Has anyone ever done custom made 5 grooves crankshaft on the 5vz-fe?
  211. 3rd gen 4Runner know how (read before you ask)
  212. Supra MAF Sensor...
  213. Swap 99 cluster for 01?
  214. Fuel pump died
  215. Finally found the little gremlin....bushings and sway bar links
  216. Amsoil filter torn up!
  217. Transfer Case Issues
  218. itty bitty lift
  219. Anyone running Greddy Emanage Blue on their 5vz?
  220. Difference between 2wd A340 and 4x4 A340?
  221. Metal Dust in Rear Gear Oil, what is it from?
  222. Brakes sticking
  223. rebuilt driveshaft and i still feel vibration ? ?
  224. 2000 tacoma spark plug wires
  225. Estimated cost to replace exhaust gasket ring
  226. 3.4L Engine Problems
  227. '99 Automatic tranny reluctant to shift gears
  228. 1997 4runner; a/c fuse blowing
  229. Tundra springs with ????? Shocks
  230. Preventative Maintenance... what a wonderful thing!
  231. OME Struts with Stock Springs
  232. 3rd Gen 4Runner Lock/Unlock Alarm Beep... How to change?
  233. low beam lights flash or turn off
  234. Auto tranny stopped downshifting
  235. Tow Report - 12x6 UHAUL Utility Trailer w/ 02 SC DC, Demello Off-Road Bumper
  236. 1997 runner rear window stopped working
  237. Struts for OME 881's
  238. Help I Need The Right Part Number!!!
  239. Will the 231mm Tundra Brake Upgrade work with 2002 Limited Rims?
  240. '96 SR5 failed NOX gas
  241. Switch for trunk 12V aux power
  242. Flashing ABS Light
  243. Can anyone use these projectors for a retrofit before I sell them?
  244. Remote rear window button
  245. Messed up blower fan
  246. Rear A/C
  247. Heater control (rotary) tough to turn
  248. a/c smells like men's urinal. :(
  249. Remove interior pieces
  250. Custom 4Runner Rear Bumper
