All-Phase Skid plate question
Old Oct 17, 2010 | 05:07 PM
metalhed's Avatar
Question All-Phase Skid plate question
Greetings I am trying to put on the All-Phaze transmission skid plate and am having a heck of a time.
The plate is a bolt on product. It came with templates for drilling holes in to the frame. Problem is -- How do you get a drill into the area to drill???
The passenger side holes are basically out of line of sight, due to the exhaust, and the drivers side holes are not much better, mainly due to space.
I cant drill from the outside in, the sliders are in the way. I have looked at air powered right angle drills and not sure that this idea will work, due to the amount of metal to drill through (both sides of frame rails.)
Taking the exhaust off is not going to happen, it really only solves one side of the problem.
Anyone else running this skid plate and what tricks did you use.
thanks
I will try to get pictures in the next few days.
Old Oct 17, 2010 | 05:20 PM
camo31_10.50's Avatar
i thought all skid plats bolted to the bottom of the frame, and not the inside of them?
Old Oct 17, 2010 | 07:06 PM
metalhed's Avatar
This one attaches from inside the frame. Fits right up in between the frame rails and is bolted through the rails. There are two bolts that pass up through the trans crossmember, to hold the front of the skid plate, the other 4 bolts are on a horizontal
Old Oct 17, 2010 | 07:11 PM
scuba's Avatar
Never heard of a company called All-phase.
Link?
Old Oct 19, 2010 | 03:36 PM
metalhed's Avatar
All phase is out of business now and there is little to no info on the interwebs
Old Oct 19, 2010 | 06:14 PM
Gerdo's Avatar
The good news is that the frame is pretty thin. You may need to use a right angle drill and may also need to cut a drill bit off to make it short enough to fit.
Old Oct 20, 2010 | 03:31 PM
metalhed's Avatar
Gerdo those were my thoughts thanks
Old Oct 20, 2010 | 03:56 PM
brian2sun's Avatar
Sounds like they made it a lot harder than it needed to be. Can't figure out a good reason why anyone would design a skid to mount like that with horizontal bolts.
Old Oct 20, 2010 | 08:03 PM
scuba's Avatar
The same reason the company is out of business
To be fair, don't the bolts for Budbuilt's added X member for a 3rd gen 4Runner or 1st gen Tacoma go through the frame horizontally?
Old Oct 20, 2010 | 08:49 PM
brian2sun's Avatar
That could be with the Tacos, but the 4runner already has the x member there from the factory so the Bud gets bolted to it with vertical carriage bolts.
88sasturbotoy
Jan 30, 2026 01:57 PM
colasurdo
Jan 11, 2026 08:10 AM
Jun 1, 2021 01:51 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Gravel Maker
RuffStuff
Jul 27, 2015 06:53 PM
