180k Refresh
180k Refresh
Well, my 4Runner is about one oil change away from hitting 180k, and I want to perform a full maintenance baseline. I got it at 130k and I just want to replace a lot of the standard items so I can know how long they've all been in there. Here is my list of things to do, let me know if I'm forgetting anything:
Fluids
-Transmission flush and fill
-Oil
-Coolant flush and fill
-Power Steering
-Brake
-Differential
Belts & Hoses
-Timing Belt & Water Pump
-Accessory belts
-Coolant hoses
-New tranny cooler hoses
-Close off bottom of rad (former transmission hookup)
-Air Filter clean (K&N long life filter, will be around 50k on it)
I don't need plugs as those are fairly new. Am I forgetting anything?
Fluids
-Oil
-Power Steering
-Brake
-Differential
Belts & Hoses
-Accessory belts
-Coolant hoses
At 180K i would replace:
**02 sensors
**TPS
**Clean & Test the injectors
**MAF--If you got the dough or buy a back-up (crashed vehicle)
**Check rear Wheel bearings
**Plug Wires--Or OHM them
**Fuel Filter
**Various (Front of Engine) idler bearings including fan idler bearing
Thats about all I can think of--and for the record, i am a little more premptive at maintenance than most--maybe do all those things at 200K
**02 sensors
**TPS
**Fuel Filter
Thermostat when you do TB, water pump, hoses and flush and fill on coolant.
Check rack bushings, tie rod ends, sway bar bushings, end links.
just get a whole t belt kit comes with everything plus new fan belts and rad hose for $300 bucks
http://cgi.ebay.com/ebaymotors/Timin...Q5fAccessories
Have you considered doing an induction cleaning? I did a Motorvac service on mine earlier this year (~197K) and it really breathed "life" back into my motor. It runs better and has more power than it has had in a long time. My mpgs went way up and have stayed there too (seriously, almost a 50% increase from ~11 - 16). I will be doing this at every tune up from now on for all my vehicles.
dzldust
7
Oct 6, 2015 05:39 AM
94toyy
12
Sep 14, 2015 06:18 AM
