Spacers and extended studs????
Old Oct 11, 2010 | 08:29 PM
fightman80's Avatar
Question Spacers and extended studs????
Hey folks,
I've ordered the Tundra TRD 4WD Coils and struts, and am now finding out that there are Spacers and extended studs needed to install them and give me the lift I want????
Here is a list of parts I found on Bamachem's thread which many people have agreed upon. Including Steve from SS....
Front:
For 2.5" to match OME 890/891/892
Two sets of AE Spacers and one set of extended studs: $80 shipped
One set of Tundra TRD 4WD Coils: about $200 shipped (NEW)
One set of OME N91s Struts: about $220 shipped (NEW)
Re-use OEM top plate and rubber washer.
Do I need these spacers? Can I use my Toytec Spacer? How about the studs from the spacer lift?? My Toytec spacer as a small ring that came with it.....can I use that one?
Old Oct 12, 2010 | 04:43 AM
Gerdo's Avatar
You can use either the one spec'd or any other one. ToyTec sells two different top out spacers. This one needs and comes with the studs http://www.toyteclifts.com/index.php...mart&Itemid=72 and will give you ~3/4" of lift.
This one uses the stock studs and will give ~1/2" of lift. I would use some loctite with these because their will be very little stud coming thru the nuts.
Old Oct 12, 2010 | 07:07 AM
fightman80's Avatar
Question
I think the one you posted with the studs, I ended up getting with my spacer kit, as my spacer kit came with extended studs......I'm thinking of using it in the install of my Tundra Coils and Struts.
What do you think?
Old Oct 12, 2010 | 07:30 PM
Gerdo's Avatar
That is the same top out spacer. It is just part of the internal spacer kit. It should work fine.
Old Oct 12, 2010 | 09:52 PM
fightman80's Avatar
Smile
SWEET! I buying that spacer lift wasn't a total waste!
Old Oct 13, 2010 | 04:55 AM
Gerdo's Avatar
I'm guessing that you have the 3" spacer lift http://www.toyteclifts.com/index.php...mart&Itemid=72 ? The difference between this and the 2.5" is the top out spacer. You can sell the inner spacer.
Old Oct 13, 2010 | 05:46 AM
fightman80's Avatar
Yeah, I was thinking of selling the inner spacer. I'm not sure how much interrest there is locally, not many modded 4Runners around here. Most guys around here have Jeeps, Chevy's or Fords, oh....and the occasional Dodge.
Old Oct 13, 2010 | 10:58 AM
fightman80's Avatar
Smile Looky looky!!!
Just got my Tundra Coil and Strut assemblies in!!
4x4YOTA
Aug 23, 2016 09:08 AM
primordialbeast117
Dec 19, 2015 12:23 PM
kcaudill
Oct 10, 2015 02:39 PM
crash813
Sep 27, 2015 07:15 AM
Odin
Sep 26, 2015 06:56 PM
