Spare Tire - holding Bracket
Old Sep 11, 2010 | 04:37 PM
halfstepdown88's Avatar
I've searched all over the internet and cannot find the answer, so I thought I'd ask you helpful folk over here at yotatech.
I lowered my spare tire in my 2000 Toyota Tacoma, but I can't remove the wire from the holding bracket. I tried twisting the metal part that the wire goes into on the other side, tried just squeezing and pulling it out, but can't figure it out.
Don't want to use too much force until I'm sure of what I'm doing.
How do you remove the holding bracket from the Tacoma's spare tire?
Old Sep 11, 2010 | 04:39 PM
CYi5's Avatar
Are you just trying to use your spare? Why are you trying to disconnect a wire?
Old Sep 11, 2010 | 04:40 PM
Have a flat front left tire. Was going to put the spare on and drive up to Discount Tire.
Just can't get that holding bracket off of the spare.
EDIT: and by wire, I should have said cable. Disconnect the cable from the holding bracket that keeps the spare tire hooked onto the cable.
Old Sep 11, 2010 | 05:46 PM
TheDurk's Avatar
If it's like the 4Runner, you just tip the bracket vertically when the tire is on the ground, and it's narrow enough to come through the center hub hole. You never disconnect the bracket from the cable.
Old Sep 11, 2010 | 06:00 PM
scuba's Avatar
Make sure the tire is supported and make sure the wire is not taut. The plate attached to end of the wire will hang loose from the rim. You can then shove that plate through the hub hole on the rim. No need to remove that wire from the top of the bracket.
KISS
Old Sep 11, 2010 | 06:25 PM
Thanks!
Damn some solutions are so simple....
I just had to hit her a few times to get it loose. Then just slit it through.
Old Sep 15, 2010 | 01:44 PM
Phoenix Ray's Avatar
spare hanger
Also the nice guys at Discount notified me that the spare tire gets mounted with the air valve pointing down, so that it may not hit any mounting points. fyi.
94whiterunner
9
Sep 22, 2015 07:28 PM
coffey50
Jul 28, 2015 10:55 AM
DrZero
18
Jul 24, 2015 11:31 PM
DrZero
Jul 13, 2015 09:59 AM
skoti89
Jul 8, 2015 12:05 AM
