clicking noise!
Old Sep 2, 2010 | 06:52 PM
billkmiami's Avatar
Question clicking noise!
My 1997 4 Runner with the 3.4 motor has a clicking sound coming from under the middle dash area when I press on the break pedal- only when the car is in park- in drive there is no clicking?? What is this?? thanks
Old Sep 3, 2010 | 06:15 PM
tunnelmotor99's Avatar
Not sure but it's probably the shift lock solenoid. It locks the shifter into P until you press the brake pedal. If that's what it is, that's normal.
Old Sep 3, 2010 | 06:51 PM
billkmiami's Avatar
if the truck is in park- I pump the brake pedal and each time, it will click- does sound like a solenoid- never did this before- solenoid is about to "blow"?
Old Sep 4, 2010 | 09:11 AM
hogman73's Avatar
my o3 4 runner is making some weird noies from under the dash also. just had it in the shop to get the remote start fixed, they put a bigger relay in the remote start so i'm going back to them to see if they know whats making my noise, i'll keep you posted. my noise is more than just a click though.
Old Sep 4, 2010 | 11:15 AM
J2F42C's Avatar
How is your brake pressure?
2wd or 4wd?
If you want to see if the shift lock solenoid is bad, remove the center console. You will see a cylinder looking plastic tube located in front of the shifter covered by a metal brass colored bracket. Follow the wire(s) from the end of the solenoid to the 6 pin (4wd) or 2pin (2wd) connector on the left hand side. It should be covered by a black foam piece. Use a DMM to check for continuity, looking from the top of the connector down, with (+) being on the left for the 2 pin connector and the top left for the 6 pin connector. Good is between 21~27 ohms. Replace the shift lock control switch at the same time.
Old Sep 10, 2010 | 09:24 PM
billkmiami's Avatar
brake pressure is ok- pedal goes down closer to the floor than i like but this seems to be normal with the 97 4 runners- i have a 2wd- (girl truck) my brakes were always like this since new.........
I will try your advise with the shift lock solenoid- now the sound is gone???????
thanks
gibbonsballer10
Oct 26, 2023 07:13 AM
4Xtruck
16
Sep 24, 2015 09:38 AM
langry345
Sep 14, 2015 03:36 PM
skouba
Sep 14, 2015 06:58 AM
Streetrod19772000
Sep 10, 2015 06:22 PM
