Swap 99 cluster for 01?
Old Sep 2, 2010 | 10:10 AM
Juppers's Avatar
I've been searching all morning and can't find anything. Is a 01-02 4runner cluster wire compatible with a 99-00 4runner? I've got gas gauge issues and don't want to play cluster roulette with 99-00 clusters and end up with the same problem. I can't find any place that will sell the combo plate #3 without having to install it as well, and I can find used clusters for less than the price of the new plate.
Old Sep 2, 2010 | 10:13 AM
DeathCougar's Avatar
No they are not the same. Different wiring setups, different some different gauges, etc.
You COULD swap the fuel gauge from an 01-02 into your 99 though.
Old Sep 2, 2010 | 10:31 AM
Juppers's Avatar
The fuel gauge electronics is part of combo plate #3, which handles the odo, speedo, etc. I don't see how I could switch just that if they aren't wire compatible.
Old Sep 2, 2010 | 10:35 AM
The fuel gauge should just come out as a seperate assembly. Its not part of the speedo, odo, etc as far as I know. Usually just held in with 2 screws to the circuit board
Old Sep 2, 2010 | 10:41 AM
Just went out and verified on a cluster that the Fuel gauge is indeed seperate from the speedo, etc.
In fact, Toyota does list two different part numbers for the two years.
99-00 83882-3D250
01-02 83882-3D570
You MIGHT be able to swap these fuel gauges. I was slightly incorrect when saying you COULD, or at least a little vague. Just because it will swap, doesn't mean it will work correctly. Again, different electronic systems.
Old Sep 2, 2010 | 10:50 AM
Juppers's Avatar
Oh! You are talking the physical gauge. I'm trying to avoid TSB010-00, which lives in the combo board.
Old Sep 2, 2010 | 12:33 PM
Circuit board?
In that case, the circuit boards definetly cannot be swapped. The biggest glaring difference is AWD which the 01-02 has, while the 99-00 is true 4WD. The 01-02 gauge cluster has a big chassis/awd indicator smack dab in the middle, the 99-00 just has a 4WD light. The clusters are wired totally different
Old Sep 2, 2010 | 01:50 PM
Juppers's Avatar
My 99 Limited has the big chassis/awd indicator smack dab in the middle. I have the AWD mode as well.
The combo #3 is the same for all 99-00 4runners, regardless of 2x4 vs 4x4, or auto vs manual, or limited vs sr5. There is a difference between vin numbers though. VZN18 has a different part number than RZN18.
Regardless, I found a blown resistor on the back of my current board, and jumpered around it. Now my fuel gauge is working perfectly again. Thanks for the help!
Old Sep 2, 2010 | 02:23 PM
Hmm.....well I stand corrected then.
I forgot the Limiteds were AWD. Silly Toyota. My 99 and 2000 were both SR5.
mussy01
Dec 13, 2016 08:20 PM
gary4runner
Sep 24, 2015 12:53 AM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
Esibnitsud
Jul 30, 2015 08:21 PM
