PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 [145] 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. Special tool for front diff?
  2. Clinometer in-dash mod
  3. The first dent is always the toughest!
  4. HELP! 2nd Gen finally died!
  5. Air horn switch ??'s
  6. Sucky Gas Mileage
  7. I'm flaked, but synthetic . . .
  8. 95 Canister Questions
  9. Remove Running Boards on a 97 With Chrome Fender Trim
  10. Clutch issues
  11. Brembo Rotors and Perf Friction Pads
  12. Looking at a newer runner...
  13. Big Question Need Big Answer
  14. How big is your....
  15. Any Ideas ???
  16. whats a good replacement fuelpump for a '94 3.0?
  17. Brake Pads and Rotors
  18. 95 runner rear window
  19. Anybody ever take off a front fender?
  20. Questions on Amsoil SDF34 clearance
  21. 305/70/R16's What's the optimal back spacing?
  22. Loose Spare Tire?
  23. loose e-brake
  24. Door moulding
  25. Annoying ticking...
  26. pics of my lifted 1st gen.
  27. Front Lower Control Arm bushings
  28. High Pinion Axel ? ? ? ? ? ? ? ? ? ?
  29. Fluid Changes/Maintenance
  30. Deckplate Mod?
  31. Truck has trouble starting 86 22-rte
  32. Initial hard starting
  33. 2003 V6 valve clearance specs?
  34. Auto Trans not shifting into gear
  35. 4th Gen double-decker Mod – Pics
  36. What is this?
  37. Air box gurguling
  38. 1988 IFS front wheel bearing help!
  39. new windshield in 86 runner (molding ?)
  40. 1992 Toyota pickup with 93 LT1 motor swap
  41. Got SS Frankenstruts 3.0 on!
  42. e-locker retrofit write up not working?
  43. Nightmare ATF change - need help bad fast!
  44. Brake problems Help...
  45. 3.4l 5vzfe???
  46. Aftermarket Plug wires
  47. Fresh Tech 7 18 04
  48. Anyone ever heard of Turkey Bay OHV area?
  49. 93' Truck Manual tranny problems
  50. new wet okoles are in
  51. Valve Clearance Check Cost on 3.4L
  52. autodimming mirror w/compass install writeup!
  53. Crane Cams Hi 6 install help needed
  54. Info for 3rd Gen owner!!
  55. Killed the Alternator and then some,
  56. bilstein shocks question
  57. 1997 4Runner Limited - value?
  58. Thinking of selling SC...
  59. 1st Gen Brake Caliper Help...
  60. ISR mod Question...3. slow
  61. how to deactivate "maint" light
  62. Question about headers/exhaust system?
  63. Scion HU in 3rd Gen 4Runner or Tacoma???
  64. does this look right?
  65. Piston slap or rod bearing? STP pretty much stopped it
  66. best high performance cone filter for intake?
  67. Coolant Hose ??????
  68. PLEASE HELP - ON vacation in Charleston, SC
  69. check engine light question???
  70. 3.0 Idler pulley removal
  71. Head Gasket ?
  72. Bed cover suggestions needed for Taco
  73. Anybody selling a 4Runner or Tacoma in Las Vegas?
  74. Rear end Noise
  75. ridin hi now
  76. 3" Performance Acc. Body Lift
  77. Wicked
  78. Transfer Case HELP !!!
  79. 94 Toyota pickup starting problem
  80. I'm an idiot...
  81. new suspention woes...when will the shocks settle??
  82. gen4: where is the a/c temp sensor?
  83. timing belt please help!!!
  84. Houston people?
  85. Hoodscoop Hood Source?
  86. New brake pads and caliper overhaul questions
  87. 1996 Toyota 4Runner 4WD proportioning Valve?????
  88. '95 Taco leaf springs
  89. 1st Gen Ball Joint Spacers
  90. 2.5" Front Spacers
  91. Trd Shocks For a 3rd Gen 4runner
  92. 4g runner (pink) taillight
  93. Idler Arm
  94. Rims and Tires for 4g Runner
  95. 3rd Gen 4Runner new Rear Bumper, need one?
  96. Stuck CV axle and stuck front diff drain plug. Help!
  97. Marvels Mystery oil and MPG
  98. Light Bar--Any interest?
  99. planning to flush radiator
  100. 4th Gen Headroom
  101. Cruiser coil measurements
  102. 3rd gen auto owners with a BL
  103. Anyone have a surfboard rack??/ need to get one
  104. Changing the Thermostat (3.4L)
  105. Planning on a Brake Fluid Flush This Weekend
  106. Buying a used 4Runner...need advise newbie to off roading
  107. Electrical guys I need your help.
  108. Need opinions on lift and tires
  109. 4th Gen with Safari Bar (color matched) and Piaa 520's
  110. Payloads? & What do you haul in your truck?
  111. Yotatech I havea treat for you! Rubicon Pictures / New Rear 4Runner Bumper
  112. Nice Articulation Pictures!
  113. straight axle torque rod question?
  114. Billet Grill
  115. THIS is why you dont use Bosch 4+ Platinum spark plugs!!!!!!!!
  116. What.s your RPM ? ? ? ? ? ? ? ? ?
  117. So I AMSOIL'd, Seafoamed, etc, and...
  118. TRD Gauge Pod
  119. Landcruiser Springs
  120. Spacers
  121. Once again thanks!!!
  122. Warn power interrupt kit tip
  123. Turbo Question
  124. ATTN: San Diego Area
  125. Update on speedometer woes.
  126. door panel fasteners?
  127. Tech1s on 01 Taco?
  128. Torque specs?
  129. which brush guard???
  130. 97 runner - clutch fluid replacement?
  131. I want to manually work the Torque converter lockup
  132. 22RE Valve Adjustment
  133. Symptoms of a bad injector or spark plug???
  134. No 4WD
  135. Bought a 4runner! !!!
  136. 1st gen digital cluster FA on ebay
  137. Grease gun
  138. Rock sliders in the north east?
  139. delima, keep or scrap?
  140. I'm Back!
  141. Those with the SC kits
  142. Tintguys or Tintprecuts
  143. New Member Here
  144. 33" tires on 2nd Gen 4Runners
  145. quick help - will these stock wheels fit my 91 4runner? *pic*
  146. Sell 95 for a 98 Runner?
  147. New owner/ Where do you buy your parts??
  148. Is this normal?
  149. Tranny temp guage 2nd gen.
  150. TRD's 5 PSI Pulley for the V6 Superchargers
  151. Any iof you guys with billet grilles, where did ya get em
  152. Antenna Hole Plug...
  153. Optima Battery...
  154. FTC1 Help
  155. Thinking of saleing ARB Front bumper
  156. Does TJM 17 for Tacoma fit Same year 4Runner?
  157. Replacement rear bumper?
  158. Rear Bumpstops on '99 4Runner
  159. Black letters out MUCH BETTER!
  160. 22re idles a little rough and smells rich
  161. Got some new goodies for my truck!
  162. Would like some opinions... possibly getting new'er' truck
  163. Any ideas?
  164. EGR gasket
  165. Clutch Problem on '93 P/U)
  166. ExtremeAire question
  167. How to change your 3.4L PCV valve
  168. slow to start after its hot
  169. 1990 4RUNNER 2nd Gen - 4 wheel drive
  170. brake pads replcd and rotor resurfaced for $200?
  171. Tacoma A/C just average on cooling ability?
  172. what do you think?
  173. lift done, wheels on!!!!
  174. Once again, where to mount some lights?
  175. muhahahahhaha (pics inside)
  176. Transfer case rebuild kit
  177. 3.4 Swap Wiring information/advice...
  178. removing guage cluster
  179. How Much???
  180. How to change the brake lines/hoses?
  181. sway bar bushings
  182. After market fuel filter OK?
  183. sealed beam to H4 style head light kits, anyone!
  184. any info on toyota's hybrid trucks?
  185. rear passenger assist grip
  186. Exhaust Woes
  187. Anyone need AC parts for 96-01 6cyl. Runner
  188. Steering Column Clunk - Tilt Wheel
  189. 98 4runner tires
  190. V6?
  191. Sensor?
  192. Bad tps?
  193. List or diagram needed of necassary mounting hardware for OEM 99 4runner fender flare
  194. Gauge Faces
  195. 1st gen 4runner newbie - A/C shakes!!
  196. Ball joint spacers -- any issues?
  197. The 30K mile Service!?!?
  198. How much to ship a truck over from Euro?
  199. Badland Bumper Time!
  200. All pro parking brake
  201. Air Tank?
  202. Fuse Help
  203. To any of you thinking about an oversized aftermarket intake on a 3.4
  204. Should I install the body lift?
  205. Almost had a fit of rage on the tire shop yesterday!
  206. Best Product to Clean Tran Pan
  207. Highlander upgrades...
  208. body lift for my runner
  209. Would this fit my 01 prerunner
  210. All parts are in, the SS 3.0 in Frankenstrut.
  211. Suspension Recommendation?
  212. PICS of my runner on 36x12.5 swampers!
  213. Tires. Could Use Some Help
  214. Replacing My Starter...HELP!!!
  215. Found a sensor that I think should be in the motor.... What is this?!?!
  216. Loss of power
  217. Toyota- ISM ?
  218. Flex-A-Lite Fan Owners!!! POST REPLIES!
  219. To Paint or Not To Paint...
  220. tire size?
  221. amsoil air filter part number?
  222. 3rd Gens w/ Compass & Dimming Mirror - FIRE HAZARD!
  223. Vehicle Info Placard....?!
  224. which cat back system
  225. A/C help needed!!!
  226. I Am Obsesive Compulsive!
  227. Mechanical Oil Pressure Gauge
  228. Is it true TOR has banned YotaTech members from purchasing parts?
  229. Ebay. Theres a TRD Exhaust for $250. Heads up.
  230. OEM parts sources
  231. "New" rims finally installed
  232. lift blocks: pros and cons
  233. Manifold Leak
  234. 3rd gen. with 15" calipers - which 16"x8" rims don't hit calipers?
  235. Cornfeds all around
  236. another interesting ebay find
  237. 2" body lift question
  238. Adding coil spring spacers
  239. How to check u-joints?
  240. Anybody have a Highlander with VSC?
  241. Need help with wiring, please...
  242. Two Unrelated Odd problems, just read this.
  243. Low idle followed by stall
  244. Replacing PCV Valve
  245. 92 4x4 3.0 - Hard to start when warm
  246. New owner/ looking for service manual
  247. Good Online palces for TOYO OEm parts
  248. recharging A/C when not completely empty?
  249. Power Antenna fixed! Thanks Bob!
  250. 2005 4Runner 411 270 hp!!!
