loose e-brake
Old Jul 19, 2004 | 04:58 AM
neutronsr5's Avatar
loose e-brake
Hey, forgive me if this is obvious.
The ebrake handle seems loose. It takes no pressure to pull it up around 3/4" to turn the brake light on (it clicks after that though). The braking power on the ebrake is weak too. I tried tightening the cable on the handle (which worked until I started using it), adjusting it (by going reverse and pulling ebrake, and also adjusting the rears by removing the oval black rubber piece in the back and clicking it with a philips).
Another problem I have that I think is related to this is when I start the car and begin to move I hear a squeal. This only happens at very low speeds and usually louder after I use the ebrake. I'm thinking that the rear brakes might be too tight causing the squeal.
Sorry for the lengthy note. But I had this for a month now and am too broke to go to the mechanic!
Thanks for the help.
Old Jul 19, 2004 | 05:53 AM
seaflea's Avatar
It sounds like youre rear pads are worn out. Thus the loose brake cable and the squealing.
Maybee someone else will chime in with a better answer.
Old Jul 19, 2004 | 02:09 PM
User 051420's Avatar
I too had this problem! My rear shoes were cracked, badly. I had them replaced along with the drum, and it got better, but the stopping power still wasn't as good as it used to be.
Just yesterday, I pulled off the rubber plug thing on the backing plate and adjusting "something" up 8 clicks. Works great now! Do a search, I'm sure you'll find the same thread I did on the click adjustment.
spiewaker
Dec 16, 2015 01:10 PM
Davebarbier
Nov 3, 2015 03:28 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
Bowman5115
Sep 29, 2015 08:55 PM
Bowman5115
Sep 19, 2015 03:04 PM
