95 runner rear window
Old Jul 19, 2004 | 09:10 AM
Blackulua's Avatar
Swicth would not activate window to go up or down.Is it the window relay that giving the problem if it is what do I do?
Old Jul 19, 2004 | 09:22 AM
Cebby's Avatar
Make sure the rear wiper is seated where it should be. If it is hung up, the window won't roll up/dn
Old Jul 19, 2004 | 11:07 AM
FROZEN4RUNNER's Avatar
Do you hear the motor or is there no sound at all. I just fixed mine. Motor gears were stripped. I got a 91 camry rear left window motor. It bolts right in and just wire it in reverse and it works like a charm. A cheap fix for all those who suffer from this common problem.
Old Jul 19, 2004 | 11:44 AM
Astralplane's Avatar
It may sound stupid but check to make sure the tailgate is completely closed, and the window lock button is off.
Old Jul 19, 2004 | 01:18 PM
Robinhood150's Avatar
Lots of times soda and junk will contaminate the contacts in the switch. I usually push the lockout switch and the window switch 10-20 times each and it works again.
Old Jul 19, 2004 | 02:12 PM
KevyWevy's Avatar
yeah check the window lock button
4x4-runner
Feb 26, 2017 06:42 AM
warrenjcarlson
Jul 22, 2016 11:47 AM
voiddweller
19
May 2, 2016 09:10 PM
Corey
Jun 19, 2002 11:06 AM
