Rear Bumpstops on '99 4Runner
Old Jul 14, 2004 | 06:34 PM
dragr1's Avatar
I have Old Man Emu rear firm coils and shocks. I did not remove the factory spring isolator cone when I installed the lift.
Am I losing rear travel by having it in?
Should I trim the isolator shorter? or
Should I remove it and get Steve's super soft rear bumpstops?
Old Jul 14, 2004 | 06:48 PM
Albuquerque Jim's Avatar
I doubt you are losing any stuff because it's in there.
I left mine in there (1/4" lift) and I have Steve's Supper Soft Bump Stops...
Old Jul 14, 2004 | 06:57 PM
dragr1's Avatar
So the axle hits the isolator and the frame mounted bumpstop at the same time, I'm assuming. In this case then, the isolator neither helps nor hurts, it just gives 1/4" lift with the springs?
Old Jul 14, 2004 | 07:02 PM
BruceTS's Avatar
Leave the stock bumpstops and Isolators, you don't need to change them. The only issue you may have is the driveshaft hitting the fuel tank skidplate, just clearance the plate.
Old Jul 14, 2004 | 07:11 PM
dragr1's Avatar
I've had this setup for about 20,000 miles now and I've had the rear maxed out numerous times and have never had the driveshaft hit-that is one reason that I thought there might be some more flex to be had in the rear.
Old Jul 14, 2004 | 07:41 PM
RTdawgs's Avatar
ive never hit the gas tank either and im confident its the shocks thats limiting the rear travel.
Old Jul 15, 2004 | 03:26 AM
dragr1's Avatar
So maybe we should get rid of the isolators, notch the gas tank, and run longer shocks. I have seen a little part that allows you to convert from the type of rear shocks we have to a conventional style shock (eyelets on each end), that would open up all kinds of shock lengths for us.
Old Jul 15, 2004 | 04:04 AM
aowRS's Avatar
I would vote to leave it in. The shocks limit your down travel and the frame-mounted hard rubber stops above the axle tube limit your up travel. The rubber used on the isolator cones is so soft and compressible, I would doubt it has any affect whatsoever.
Andreas
Old Jul 15, 2004 | 04:28 AM
bamachem's Avatar
Mine are totally gone, and I get a good bit more stuff than dragr does on the same inclines. I also don't get enough droop to come close to hitting the gas tank, but that's going to change really soon... I vote for at least taking a hack saw to the bottom button on the bumpstop - maybe even the bottom three and add some air bags for towing - you'd be VERY suprised w/ the difference. When you go offroad, you simply remove the stem from the valve for the bags and they completely compress w/o limiting travel. I'm seriously considering getting some more air bags for the rear coils. If I do, the conical bumpstops will go back in (trimmed) and the bags underneath them.
Here's some pics with the rear stuffed. That's Downey 3.5" rears w/ OEM shocks. I'll be ditching the OEM shocks soon...
http://4rnr.net/rides/tellico-07-10-04/images/t-04.jpg
http://4rnr.net/rides/tellico-07-10-04/images/t-05.jpg
http://4rnr.net/rides/tellico-07-10-04/images/t-06.jpg
Old Jul 15, 2004 | 04:31 AM
bamachem's Avatar
Andreas
I disagree 100%. On a NON-LIFTED runner, cut off the "soft" conical bumpstops and replace them w/ air bags and see how the ride changes. Night and Day. Those things will give on a slow stuff, but they DO limit travel.
Old Jul 15, 2004 | 04:34 AM
aowRS's Avatar
Point taken. I humbly shuffle away with my tail between my legs...
Andreas
Old Jul 15, 2004 | 04:39 AM
bamachem's Avatar
Andreas
LOL... don't take it that way... I'm glad you posted. It's good, honest, opinionated discussions like this one that make this board so interesting and helpful.
I just respectfully disagree. I had a 2wd that i put some TRD bags on in the rear for loads and towing and it was MUCH better than the bumpstops...
Old Jul 15, 2004 | 04:56 AM
sschaefer3's Avatar
I'm confident its the shocks thats limiting the rear travel.
Gee Wiz Skippy you think? You can be more than confident, you can be certain.
They bottom out harshly too. MOST people don't get the bump stop thing, but it is one of the more significant improvements.
Now there's 2 ways to do it, the cheaper way and the completely bolt on way.
Old Jul 15, 2004 | 05:03 AM
bamachem's Avatar
Originally Posted by sschaefer3
They bottom out harshly too. MOST people don't get the bump stop thing, but it is one of the more significant improvements...
No kidding. They'll jar your damned teeth just going over speed bumps. Take them out ( or just trim them an inch or two) and the ride is less "controlled" but MUCH less HaRsH.
Old Jul 15, 2004 | 05:22 AM
RTdawgs's Avatar
Andy - compare your Crawfords flex pics to mine. im runnin OME 890 and N86C.
http://community.webshots.com/user/rtaylor84
Old Jul 15, 2004 | 05:33 AM
bamachem's Avatar
Won't load... VERY SLOW.
I've seen them, and you've got some NICE flex. I'll check them out and edit this when I can get them to load.
Old Jul 15, 2004 | 05:34 AM
RTdawgs's Avatar
i just loaded them since my website has taken a ˟˟˟˟ on itself.
its working for me now.
Old Jul 15, 2004 | 05:37 AM
bamachem's Avatar
you must have gone to breezy's hosting... lol ouch.
Old Jul 15, 2004 | 05:39 AM
RTdawgs's Avatar
yea i did, WTF happened? he wont respond to my emails or PMs!
Old Jul 15, 2004 | 05:43 AM
bamachem's Avatar
remember those computers he was selling? he said in the ads that he was getting out of the business... lol that's why he made him self look like the "good guy" and offer free hosting. he knew when he made the offer that he was getting out of the buisness anyway...
