Sucky Gas Mileage
Old Jul 19, 2004 | 05:54 PM
Duec66's Avatar
Sucky Gas Mileage
I went on a trip this weekend to seattle. and figured out my 94 4-Runner was getting about 12 mpg is that outrageous or is that normal? I don't think its nuts any suggestions.
Old Jul 19, 2004 | 06:15 PM
Duec66's Avatar
probably going to sell it now but don't really want to.
Old Jul 19, 2004 | 06:33 PM
ChickenLover's Avatar
My 95 V6 gets about 17.5mpg + on the highway and about 15mpg around town. And I don't drive like an old lady. It sounds like you need an all out tune up.
-Spark plugs and wires
-cap and rotor
-pcv valve
-fuel filter
-upgrade your airfilter (K&N - Amsoil)
-clean your throttle body
-switch to synthetic fluids
-check tire pressure
-check timing
Old Jul 19, 2004 | 06:38 PM
sportJr's Avatar
Ok here is one for ya, I just moved back to Mn from NC. I am getting about 50 to 65 more miles to a tank, and the driving is compareable to what I did before. I did mount the tank I made that will replace the one I have under there now. It is located where the spare used to go. So I can see not having the wind tunnel right there, but not that much difference. I am wondering if it is the gas. They use more ethanol up here than there, but I did not think it would do that much of a difference.
Old Jul 19, 2004 | 06:41 PM
Duec66's Avatar
-cap and rotor
-pcv valve
-fuel filter
-check timing
thanks for the advice ill do it then get back to ya
Old Jul 20, 2004 | 06:16 AM
motrhedx81's Avatar
I get about 11 mpg's so don't fell bad at all. Tune-up wouldn't hurt.
Old Jul 20, 2004 | 03:48 PM
yep to that one, mine dropped significantly due to low tire pressure
Old Jul 20, 2004 | 03:55 PM
gwhayduke's Avatar
Yeah, but you're running 35's with a 22re...Your speedo is off, so you're probably getting a little bit better than 11...And I'll bet you're gonna ask Santa for some new gears.
Old Jul 20, 2004 | 06:55 PM
Figit090's Avatar
that sounds like it's too much...H2's get around 11mpg!! i think there would be a phenominal difference between a huge SUV with a gas guzzlin V8 and a 4-6 cyl. engine in a much smaller SUV.... you can get better... that tune up has gotta help.
Old Jul 20, 2004 | 07:20 PM
Juggalo's Avatar
What size tires are you running, and if they are bigger then 31's what gears do you have?
I get somewhere around 10mpg on my 33's with stock gears. Don't forget that the 3.0 3vze is the biggest POS 6 cylinder Toyota has ever made
Old Jul 20, 2004 | 09:57 PM
Duec66's Avatar
i'm running 31s, and i didn't know about the 3vze being a pos. i'll probably just sell it, instead of waisting my money on a overhaul of a pos.
Old Jul 21, 2004 | 03:53 AM
motrhedx81's Avatar
Naw, Santa the taxman visited last spring break with the new gears (5.29's). The new gears and 35's actually corrected my speedo for the most part. Now it runs pretty close to stock compared to stock gears with 31's. With the old setup at 55, my speedo said about 45. It was about a 10th of a mile off. I do need a tune up though, but I'd rather save the money to do an engine/tranny swap .
Old Jul 21, 2004 | 08:51 PM
88yotaboy's Avatar
Ive got 31's with stock gears and after accounting for my spedo being off im still getting 18+ mpg. Something is deffinetly wrong if your getting 12.
he's gone
7
Dec 3, 2019 07:08 AM
accuracy
Aug 30, 2015 09:47 PM
raptor510
Aug 19, 2015 02:15 PM
Tacoma1313
Aug 17, 2015 05:44 PM
nonstop
7
Aug 11, 2015 09:26 AM
