Manifold Leak
Old Jul 12, 2004 | 12:57 PM
4Hummer's Avatar
Manifold Leak
Okay guys need some advise.
I've got a nasty TICK TICK TICK from my truck when its cold. Traced it down to the exhaust manifold gasket. (Black carbon all over 1 of my new wires) So I went to the stealership and picked up a new Gasket. Popped the gasket in And lo and behold the last two bolts to tighten the manifold down are STRIPPED. Well ones not even there and the other won't tighten fully down just spins.
Is there an easy fix ? I'm a little weary of re-tapping these holes myself with my tap and die set, to a larger thread size, A machine shop is probably going to charge me an arm and leg to do it.
And I don't want to weld the manifold on either. (Thought crossed my mind)
What other options do I have ???
Old Jul 12, 2004 | 01:10 PM
radrex's Avatar
Helicoil inserts should do it...
Old Jul 12, 2004 | 01:34 PM
4Hummer's Avatar
Whats a Helicoil and how do you use them ?
Blamalam
Mar 12, 2022 07:34 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
romex1
Aug 10, 2015 06:21 PM
accuracy
Aug 4, 2015 08:05 PM
87blyota
Jul 10, 2015 04:31 AM
