PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 [151] 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. Whistling when engine is cold
  2. Tacoma and 4Runner... Quick Q...
  3. TX4Roc.com Launched!
  4. Should the Forum be seperated by model?
  5. Bought an 85 4-Runner last night and have some questions.
  6. help with difference of long and short FJ coils
  7. check engine = MAF
  8. What's your method of taking off nasty grime?
  9. What's your favorite rear bumper design?
  10. How common is it to break manual hubs?
  11. UNI FILTER brand air filters
  12. Idea for increasing gas milage
  13. 3.0 couple of tune up questions w/ pics
  14. someone please show me how to do this or I'll break something!
  15. Hyper Grounding (claimed 5 hp gain)
  16. Tranny Cooler
  17. How can I check the "check engine light" codes on a '00 4Runner?
  18. Dropping '89 4runner v6 oilpan????
  19. reverse lights stopped working
  20. price for 96-97 taco
  21. New High Jack And Mount To Stock Roof Rail
  22. PIAA questions...
  23. Potential New Member: Looking for a 3rd Gen
  24. Damage at the wheel edge - is it okay?
  25. Performance Chip or Rip off?
  26. 4th Generation - missing trim
  27. Need help ASAP - anyone with a 96 4runner (or same gen)
  28. How much to sell my 92 for?
  29. truck goes down the road sideways
  30. Anyone ever use the Ever-Wear 3 step Fuel System Cleaner
  31. Forever Black is the shizzle!
  32. Can't find peel-n-seal...
  33. Q about Revtek lift and CV angles
  34. Intermittent Power Loss 3.4L S/C
  35. how much $$$ for a transfer case?
  36. Any Last Thoughts......
  37. A/C light - Power?
  38. Need fender flare for 01 4 Runner
  39. Electric fan for my 2nd gen
  40. Dragstrip results: 2.2 Pully stock injectors...
  41. Now i know 3.slow
  42. Cruise coil lift
  43. 22re TPS help
  44. tire/wheel fitment
  45. Anyone noticing better gas mileage now?
  46. Pic of Big Bad Blue catching some air
  47. New pictures of my rig
  48. Daystar v. Revtek
  49. bigger tires
  50. Rear Bumpers...
  51. Will the 3.slow tow?
  52. LT 27x8.50R14 vs P205-75R14 tires...
  53. well.. im officially an owner of a 92 toyota pickup...
  54. 94 Runner engine problems
  55. missing bolt
  56. 22RE bad noise at 3500 rpm
  57. how long have you had your rb body lift?
  58. Squeaky belt - too tight or too loose?
  59. Best oil for high mileage
  60. jack tool
  61. AIR HORNS or HOOD SCOOP
  62. Taillights what year ??
  63. Got my PC Polisher today!
  64. New guy onboard...
  65. Who really enjoys the mud???
  66. need help with a chirping noise - 97 4runner
  67. No rear brakes!
  68. speakers for 01 taco???????
  69. HID Help
  70. Manual hubs - how do they help? Are they worth it?
  71. Custom Exhaust
  72. Cruise Control With a 3.4L Swap?
  73. cant find soft top
  74. A Lil Noise
  75. 84-87 horn & dome light problems
  76. Tacomas can flex!
  77. Picture with High-Lift / Roof Rack / Roof Lights , Finished
  78. Factory Alarm Questions (2000 4Runner Limited)
  79. HELP! I got ran off the road and smacked a rock now............
  80. 4 Runner Tacho wiring diagram
  81. tacoma third member
  82. 3.0 A/C Help
  83. Are metal tabs necessary?
  84. Reservoir shocks - a few questions
  85. 4th Gen lighting
  86. Gas Mileage on 1st Gen.
  87. Valve adjust specs for TRD Stg 1 cam 22RE???
  88. best coilovers
  89. Scofco and BBB please read....
  90. Overheating?...or not?
  91. tranny?
  92. Anyone Ever re-build their 3.4? HOw much HP?
  93. New LIft - Before and After Pics
  94. what ratio is this
  95. New Clean Pics and Question on how to remove front/rear bumper and License plate surr
  96. Oil leak? (pics)
  97. Who runs 305's w/ 4.25 BS
  98. Finally A Pic of the 88 4Runner
  99. Too Good To Be True???
  100. Coil resistance check
  101. Help! White Smoke Again
  102. Leaking Shock
  103. molybdenum disulfide lithium grease
  104. Cardan Joint Info
  105. How to replace control arm bushings?
  106. CV boot replacement on 2nd gen...help
  107. Need to replace all my shocks! =(
  108. Question for those using window channel fitting weather guards
  109. Want some Subwoofer input for 91' PU
  110. One or Three Piece Brush Guard?
  111. puff of smoke
  112. Goin' up! (pics)
  113. RB Body Lift--Bolt size
  114. Starter Removal woes
  115. Towing for the first time..
  116. 265/75R16s they rub, but...
  117. parts?
  118. SAW 650 vs 675 lb springs?
  119. Need help with manual hub conversion!
  120. Steering stop noise - please help - need pictures!
  121. Guess I should introduce myself
  122. 7th injector alternatives
  123. Aux heater
  124. Thinking about sliders. I got questions.
  125. installing cd/mp3 deck -problem with AM
  126. HELP! Revtek diff drop
  127. 235/70/16's
  128. Intrest in Buying Pan Hard Drop 2nd Gen.
  129. Body lift and Manual Transmission?
  130. Help, serious problem with 4runner
  131. coilovers vs. OME?
  132. SAWs interchangeable??
  133. Anyone with a TJM-15 please help
  134. 88 1st Gen Aftermarket TACH
  135. 1st Gen BUILD UP........UPDATE!
  136. Stock Alloy wheels with ball joint spacers!
  137. San Luis/Pismo area gearheads?
  138. New shocks when using Balljoint spacer on lifted runner?
  139. climate diagrams needed!!
  140. OK, I cancelled the order for the torsion bars, tell me about the ball joint spacers!
  141. Downey 2" rear coils and SAW 25mm mmtorsion bar combo questions!
  142. gears
  143. new brush guard
  144. running rich 3.0
  145. Torsion Bar HELP! I cant find a set ANYWHERE!
  146. What speed should it shift to Overdrive
  147. advice on a little lift?
  148. This is just plain weird...
  149. What in the world is this???
  150. 2 questions
  151. West Coast Customs 4Runner?
  152. black tailpipe on Taco
  153. What is the ratio of 4WD LO in a 3RD Gen 4Runner?
  154. Need bumper with winch
  155. dealership tried to screw me!
  156. Windshield Wiper Squeek on Replaced Windshield
  157. Just a question about locking rear differential?
  158. See ya later resonator.......4th gen hack job
  159. Sudden burning smell while engine is cold
  160. few suspension Qs (take it easy on me, I'm new lol)
  161. I STFA, was it worth the money to replace your fogs with silverstars?
  162. Newbie buying a 4Runner questions (after searching)
  163. Some info on the toyota 22re early 90's trucks...??
  164. 2004 Japan OEM 4Runner stuff
  165. Random though on balljoint spacers
  166. Question to Flecker .
  167. First time buyer 97-98...got questions!
  168. suggestions for 1st time offroading?
  169. electrical help please!!
  170. 85 4runner engine swap
  171. more lift??!- help plz
  172. OK - Now I'm mad
  173. Front Axle problem
  174. A/C not cool...
  175. Bushing size Front strut
  176. New 04 4Runner
  177. noob lift help
  178. overheating?
  179. Replacing belts
  180. *Help* In the middle of tranny cooler install, have a question...
  181. Need opinions (Pics posted) rims & tires-keep or sell?
  182. E-locker complete (entire axle) shipped for $460
  183. Agh! I Cant shift!
  184. Reseting the ECU
  185. Black Steelies
  186. Another Noobie! Yay!!!
  187. Finally Lifted
  188. Who Replaced My Brakes With A Sponge!?
  189. smell when accelerating
  190. AC idle drop
  191. PA system and speaker...
  192. Extended Brake Lines Help??
  193. OME 882 Opinions
  194. 1st gen a/c question
  195. $2,500 for a steering box? Please tell me otherwise someone!
  196. Looking for a part number/description so I can order this...
  197. Front suspension on 2nd gen 4Runner after TJM bumper
  198. Looking for BFG AT Trade (Sale) in MD/VA/DC
  199. 1st Gen after market hood
  200. V8 Supercharger - what's the best price?
  201. Lost some gauges on the way to work...
  202. '97 4Runner idle problem - HELP!!!!!
  203. One angry member!
  204. Leaking Tranny Question
  205. Bumpstops - Questions on how they work
  206. line lock
  207. oil leak help
  208. yet another muffler question
  209. 92-95 runner bumper work on 91 runner?
  210. please help,95 4runner clutch probs...??
  211. i need help!!!!
  212. 22re towing
  213. Were there changes in headlights from 2000 to 2001?
  214. Seatbelt won't retract
  215. Broken zerk - what now?
  216. Front Shocks
  217. Exhaust for 22R
  218. Problem Fixed!!!
  219. hot floor
  220. Chipped paint on a 99 limited bumper
  221. 15X8 3.5" BS with 32x11.5's - work?
  222. Towing Boat 350 miles andything to watch out for?
  223. Anyone done business with Baja Racing
  224. Anybody installing fender flares ....read this
  225. Vacuum Problem
  226. Another gearing question
  227. removal day
  228. cv boot replacement?
  229. Speedometer change w/bigger tires?
  230. 5'' of backspacing. Dangerous??
  231. What W&V of oil would you use?!?
  232. Need help with ARB bumper for 1995 4runner
  233. problems
  234. Idles Perfect - misses at higher RPM
  235. drivers door mirror
  236. Bilstein/KYB and Lift
  237. Engine Blown
  238. How much is this truck worth?
  239. how loud is your 2nd gen during acceleration??
  240. Rear DIfferential Ring & Pinion Adjustment
  241. squeal
  242. Good pix of the '05 Taco xr
  243. Idling Problems
  244. How loud are YOUR headers?
  245. 22r buildup ?'s
  246. 1984 4runner stock coil
  247. Tacoma mass airflow sensor question
  248. SDORS now SDORI
  249. Suspenison Guru's Need Help ASAP!!
  250. Swaybar removal tips and help please!!
