Vacuum Problem
Old May 25, 2004 | 05:35 PM
Praufet's Avatar
Vacuum Problem
My runner is idling rough and it was suggested it may be a vacuum problem. The guy who installed my engine tested for leaks. How would I go about diagnosing/fixing a vacuum problem?
Old May 25, 2004 | 07:51 PM
terky's Avatar
use some small hose lying around and replace the vacuum lines one by one until you find the problem. That may work, not sure tho
Old May 25, 2004 | 08:13 PM
bike4miles's Avatar
Check to see if the throtle body is sealing. That was my problem and it took me a year to figure it out!~
Old May 28, 2004 | 04:31 PM
AverysDad's Avatar
spray some carb cleaner around all the vacuum hoses one by one with the engine running..............if the idle jumps up when you spray you have a leak at that hose
Sleaker
Aug 26, 2020 06:03 AM
montanatruck
Feb 26, 2017 07:07 AM
jgwerth
Jul 16, 2015 03:23 PM
voiddweller
Jul 15, 2015 03:56 PM
TokyoD23
Jul 12, 2015 06:01 AM
