Vacuum Problem
My runner is idling rough and it was suggested it may be a vacuum problem. The guy who installed my engine tested for leaks. How would I go about diagnosing/fixing a vacuum problem?
Check to see if the throtle body is sealing. That was my problem and it took me a year to figure it out!~
spray some carb cleaner around all the vacuum hoses one by one with the engine running..............if the idle jumps up when you spray you have a leak at that hose
