Broken zerk - what now?
Old May 25, 2004 | 08:43 PM
schlopecki's Avatar
I got limiting straps for my current setup (OME 891 rear spring + OME N86C rear shock), but couldn't mount them right,
so I took them off and went off-roading anyway.
I was under the truck today and what I see? - no zerk on the rear drive shaft and a nice dent on the gas tank skid plate. :wtf:
I guess OME setup really needs limiting straps.
Anyway... what to do now?
How to remove remains of the zerk from the joint?
Old May 25, 2004 | 09:07 PM
TechWrench's Avatar
The zerk fitting should be threaded. Try using an EZ-out in the hole that remains when the head of the zerk breaks off. This has worked for me in the past.
Old May 25, 2004 | 09:17 PM
bike4miles's Avatar
also try a sharp tool such as a probe to twist it out. sometimes they are very loose and you get enought gip to swist it out.
Old May 25, 2004 | 10:12 PM
Birdman's Avatar
I used the taperd/square tip of a small metal file once.
Old May 26, 2004 | 05:10 AM
schlopecki's Avatar
Thanks guys for your suggestions - I'm gonna give it a try tonight.
Old May 26, 2004 | 05:35 AM
shazaam's Avatar
where can I get the limiting straps from? and what type (size) should I get?
On this last run, I had just installed OME in the rear and really banged things out under the truck
Old May 27, 2004 | 08:33 AM
schlopecki's Avatar
I bought them from MasterCraft.
After looking at the gas tank skid plate I rather think now that limiting up-travell will help rather than down-travell limiting straps.
Of course I'm putting the straps anyway.
BTW to get the zerk out I used a 6-arm-star screwdriver.
I hammered it into the zerk and then unscrew it.
ladybugRC
458
Aug 21, 2020 10:41 AM
punks_is_4x4
Feb 26, 2016 04:29 PM
bradahman
Oct 1, 2015 09:24 AM
Brodetski
Sep 30, 2015 11:50 PM
andrewtexas123
Sep 23, 2015 07:48 PM
