7th injector alternatives
Old May 27, 2004 | 09:13 PM
nags's Avatar
I've been reading around a lot and it seems like a necesity to get either a 7th injector or URD with your supercharger.
However, I'm running into other alternatives. Does anyone have any experience with them? One is here;
http://www.apexi-usa.com/electronics_safc.asp
the other is
http://www.maxxautoworks.com/html/5vze_fuel_kit-01.html
please let me know what you think
Old May 27, 2004 | 09:17 PM
shazaam's Avatar
don't know anything about apex .. but I think Gadget had some problems with maxautoworks awhile back ... plus their kits are a couple of hundred dollars more.
Old May 27, 2004 | 09:18 PM
nags's Avatar
a friend of mine that is very into cars and has a lot of experience with superchargers swears by the apexi one... he loves the thing and has had them on several different cars
Old May 28, 2004 | 05:34 AM
midiwall's Avatar
The SMT-5/6, which is discussed here:
https://www.yotatech.com/forums/show...&threadid=5130
Old May 29, 2004 | 09:49 AM
BlueTrane's Avatar
Do not use maxx. A few members here have had trouble with them. I'd recommend Gadget's solution. www.gadgetonline.com
Also, the aforementioned smt stuff is great if you like to tinker.
Old May 29, 2004 | 09:51 AM
nags's Avatar
yea, seems like the general consensus is the URD
Gotta save up a bit more
Old May 29, 2004 | 10:43 AM
NX Tacoma's Avatar
Nags, I have the Apexi SAFC II. It works wonders!! Don't get the first gen it has some flaw's!
Old May 29, 2004 | 10:44 AM
nags's Avatar
Do you just have the unit or do you have new injectors?
From what I was reading on another board the unit alone will make a difference but not like going with the injectors
Old May 29, 2004 | 10:58 AM
NX Tacoma's Avatar
New injectors(supra 305) yes.......7th no!
Old May 29, 2004 | 11:45 AM
nags's Avatar
Is there any advantage to just changing the injectors and not going with a full setup?
Old May 29, 2004 | 11:52 AM
Gadget's Avatar
You can not just install larger injectors. The stock ECU will not be able to cope with that kind of change. It will run like crap.
The kit I put together uses a high end engine calibrator controller. This modifies the signals from the different sensors so you can tune the engine to do what you want and have it run perfectly all the time.
My kit is a complete solution and contains everything you need to make your truck run like it came from the factory with a supercharger.
It has:
Walbro 190 LPH pump
DENSO K22 spark plugs that are two steps colder then stock
Stant 170* thermostat
URD modified Bosch 318cc fuel injectors
URD injector adapters
Split Second Fuel/Timing calibrator
Start up program preloaded in the FTC
This is the URD Stage I kit and is the building block for the Stage II kit which contains a smaller pulley for more boost and water injection.
You can get more info on the URD system at www.URDUSA.com
Gadget
Old Jun 4, 2004 | 03:32 PM
nags's Avatar
It has:
Walbro 190 LPH pump
Gadget
Already ordered the new pulley from you and about to order the full kit
Old Jun 4, 2004 | 03:34 PM
Gadget's Avatar
That is good to hear. Thank you for your trust in us.
If you order the kit real soon like in the next hour or so I will have it in the mail to you in the morning. I am packing lots of stuff right now.
Gadget
Old Jun 4, 2004 | 03:36 PM
nags's Avatar
I'll place the order right now then.. Thanks for your help over and here and at customtacos.com
Old Jun 4, 2004 | 03:39 PM
nags's Avatar
Just finished placing the order.
Can't wait to get everything installed.
So far I've got the 2nd gen SC, boost gauge, air/fuel gauge, urd kit, and urd pulley. Should that be everything I need for a smooth installation?
thanks,
nags
Old Jun 4, 2004 | 06:40 PM
Gadget's Avatar
I just finished packing your order. Good choice on the plugs.
When you say you have an air/fuel ratio gauge, what are you speaking of? I hope it is not one of those things that you hook up to the O2 sensor on the truck, because you don't have one...
Gadget
Old Jun 4, 2004 | 06:43 PM
shazaam's Avatar
I'm jelous ... I've got to take this exam and then order this kit and finally install this s/c thats been sitting here since november
Old Jun 4, 2004 | 06:44 PM
nags's Avatar
Gadget
It's this gauge
http://www.dsm-performance.com/produ...products_id=72
If I don't have an o2 sensor, what do you suggest?
Old Jun 4, 2004 | 06:50 PM
shazaam's Avatar
URD has free replacement 02 sensors .... click here
Old Jun 4, 2004 | 06:52 PM
nags's Avatar
free? I'll buy a few
