PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 [64] 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. Rear passenger drum break
  2. 285/75R16s (sorry, to beat a dead horse)
  3. 15" tires?
  4. Aftermarket 3rd Gen Center console?
  5. help me read my door tag
  6. finally the new truck
  7. 1996 LC's Installed! Pics coming up!
  8. Engine trouble
  9. 2007 FJ wheels on a 3rd Gen Runner?
  10. Shake rattle and roll after playing in the dirt?
  11. Sport Hood assembly instructions, etc
  12. Noisy exhaust
  13. Tailgate Regulator help needed.....
  14. 97 4Runner rides like a Brick, what shocks should I get?
  15. Radiator/coolant issue...
  16. Non ABS truck with an ABS axle
  17. My new Runner
  18. 32inch BFGs?
  19. tacoma ARB bumper on a 3rd gen 4runner
  20. OME front lift options?
  21. Think it's time for new springs?
  22. Mileage issues with 96 4Runner 2.7
  23. looking at 3 4runners
  24. tacoma seats swap
  25. Spark Plug failure?
  26. 2000 4runner Radio??
  27. ignition switch won't turn
  28. One last exhaust question
  29. Cracking sparkplugs
  30. thinking of tacoma
  31. 01 4Runner 4WD problem, HELP
  32. Anybody need a grill??
  33. time for new plugs
  34. Burning Rubber smell?
  35. Camry/Lexus Seats in a 3rdGen
  36. suggestions and info on a 96 runner
  37. BEWARE aftermarket fan bracket
  38. suggestions for a 96
  39. '99 4Runner & Burning Smell
  40. What have YOU done?!? (Interior mods)
  41. ABS light on with new LED tails...
  42. 3rd gen rear sliding window Question
  43. 97 4Runner Check Engine Light - P0301 & P0303 - Need good mechanic recomendation
  44. CV rebuild question
  45. Hurculined Fenders
  46. These dang stupid idiot thief?s!
  47. paint job
  48. CV joint spacers, truth or I'm an idiot?
  49. drive light goes out on 99 4-runner ( tranny trouble?
  50. Really want to buy a Yota. What do you think about this Runner?
  51. Pics of my Rig
  52. 4th gen. 18" wheels on 3rd gen. 4runner?
  53. best oils for 98 s/c 4runner 115k?
  54. 5VZFE fan housing and pulleys
  55. SS topout spacer measurment.
  56. Portland, OR - Can I borrow your crankshaft pulley tool in exchange for beer?
  57. do door vin tags usually state the original tire size ?
  58. New Idea on How to Run 2 Topouts...
  59. Need a GREAT T-Case/Axle oil. Help a new-b?
  60. The cost of converting to 4WD?
  61. Installing Coolant style Engine Block Heater
  62. Curb Idle is 1000 RPM (Warm)
  63. BOO! need some tuning help
  64. FYI 96-97 4runner gauges will not work in a Tacoma
  65. Front Diff questions
  66. MAF swap
  67. P0300...Is my timing belt replacement the culprit?
  68. Mpg
  69. Rear Diff Leaking
  70. Wiper Blade Length? 1997 4 Runner
  71. Will these Wheels work?
  72. Clunk when braking
  73. A funny "ting" noise
  74. Question for 3rd gen 4runner gurus.
  75. 96 tacoma4X4
  76. front of truck clanking somone help!
  77. Smart shift electric shifter, will it work on Toyota's?
  78. Starter Question
  79. My new tires/wheels/lift
  80. My new, sorta bling, 17" wheels
  81. Rusting OEM tow hitch...
  82. floor mat hook? does it just pop out?
  83. New CV Axle (Noise?)
  84. looking to buy this 2002 taco. What do you think?
  85. What would you pay for a rolled 3rd gen runner?
  86. high idle
  87. new to me 4runner
  88. 15"s instead of 16's
  89. mileage hits the crapper- what gives?
  90. Anyone have these 4runner projector headlights or crystal clear headlights??
  91. 02 tacoma suspension questions
  92. rear air bags??
  93. Brakes on a 2004 Toy
  94. finally got my lift tires and sliders on
  95. HELP NEEDED...checking TPS on 3.4 V6.
  96. Water and engine coolant temp difference?
  97. Was the price right?
  98. anybody ever try to clear corner their stock lights?
  99. Misc parts for sale
  100. Wheel Question
  101. 4Runner Sidemarker lamp/bulb replacement?
  102. T-Case: Manual vs. Auto
  103. Any suggestions
  104. differential fill point?
  105. Foul odor from a/c vents...
  106. Just replaced valvecover gaskets
  107. Replacing door stops?
  108. CEL only on highway
  109. Help me identify my lift?
  110. Rattling noise in drivers side dash. ideas?
  111. EGR valve location on 3.4????
  112. Rear window problem
  113. stalling problems
  114. 2000 Interior Color?
  115. Need Help, engine trouble.
  116. How much would it cost to put a ~3in spacer suspension lift on??
  117. Question about Sliders?
  118. MT tires and wet traction...opinions?
  119. pics of my ride 96 base
  120. FSM Diagrams for 3rd Gen 4Runners.
  121. Feeler: Jaos Rear Ladder (Rare) Hard to find
  122. bad a/f sensor and stubborn cel
  123. 3RZ flywheel/clutch for 2RZ?
  124. Carcol canister cracked...
  125. wiring harness for brighter headlights?
  126. Is my 2001 4Runner a Sport or not?
  127. 1996 FZJ80 Coils
  128. Tjm 17
  129. 3rd Gen TPS adjustment?
  130. need advice on 99 trd 4-runner
  131. My butt is sagin' and i need to lift it up
  132. rear diff drive shaft and axle seal ??s
  133. Weird chit going on
  134. Tire Review: Wild Spirit TXR II (285/75/16)
  135. New Plugs and Wires.
  136. silverstar ultras review
  137. Door Lock Actuator Question
  138. driveshaft noice
  139. PCV Catch Can Mod.
  140. 04 2.7l idle knock issue
  141. Did some good wrenching tonight!
  142. Trans hesitation when cold
  143. Whats the Worst that Could Happen
  144. rubbing noise when cold
  145. Supercharged 03 Tacoma pics
  146. Mysterious charging trouble on my ?96 4Runner
  147. Recommendation on stainless exaust tip
  148. Spark Plug gapping
  149. What kind of ski / snowboard rack are you using?
  150. Supercharger blew head gasket?
  151. Front axle replacement
  152. Airaid MIT quality???
  153. Driveshaft Slack?
  154. Suggestions for Auxillary Lighting on a 98 SR5 4Runner?
  155. Bog at every shift
  156. 00' rear coils for 98????
  157. Which Brembo rotors - 2 options on autopartswarehouse
  158. Fire Victims in San Diego- Can i help?
  159. Replacing clips on inner CV spindle necessary?
  160. Where to get GE Nighthawks
  161. New Shiftknob!
  162. prepairing for winter? New to snow
  163. Mobil1 ATF in powersteering?
  164. Out with the old. In with the new(ish) 4runner...((Warning: Long))
  165. 3.4 Rev Limit?...HELP NEEDED!!!
  166. v6 ranger vs. v6 tacoma????
  167. Code 0325 CEL
  168. Took the Running Boards Off *Pics*
  169. Milk Shake Tranny thing has me worried now...
  170. I like my DRL's...
  171. 3.4 L CEL on and off...
  172. NGK BKR5EKB-11 difference
  173. rear brakes no workee....
  174. tacoma seats
  175. New Hid Upgrade
  176. panhard bar?
  177. ADD solenoids?
  178. 3rd gen bumper finished
  179. Tacoma DCab 5Speed
  180. 3.4 TPS code?
  181. Need help with electrical issues.
  182. Driveline and fender flare questions...
  183. Frustration from MPG.
  184. loose seatbelts?
  185. Block heater question?
  186. 99 rear coils on 98???
  187. Photochop Request
  188. Stock spring rates ?
  189. 99+ Front Lip on 98 4Runner
  190. 4Runner questions - Newbie
  191. Power Windows
  192. fuel "boiling"
  193. Wiper motors
  194. Mounting Turn Siginals in the Marker Lights?
  195. Need good thread for lubbing the driveshaft
  196. Anybody looking to get SAWs?
  197. Who's running 245/75/16 's?
  198. 99 Fog Light Install Problem!
  199. are there websites...
  200. One thing always leads to another!
  201. 02 sensors
  202. Dilemma - Red Milky Coolant - need $.02 on my suspected cause.
  203. What is this?
  204. Rear Axel with E-Locker
  205. Steering Drops
  206. Replacement Vacuum Hoses
  207. shifter reinstall
  208. I'm thinking about buying my old 4runner back... what are y'alls thoughts..
  209. Wheels Spacers and Stock Wheels.
  210. Tire Dealer Made Mistake-Should I Ask 4 Replacement?
  211. 02 Tacoma 2.4 or 2.7 L?
  212. Tweeter Mount
  213. CHROME PACKAGE-Are 3rd Gen 4runner And Land Cruiser FJ90/100 Door Mirrors Compatible
  214. P0420 CEL Code...Any Definitive Fixes Identified?
  215. 1999 4runner Antenna
  216. where can get these lights???
  217. 97 4Runner Ignition/Spark Wire Questions
  218. Water Temp Q? for those with A ScanGauge
  219. How to tell which gearing I have?
  220. Sway Bar problem
  221. Couple 'o clutch q's
  222. Front Heat Problems!!
  223. Bear Minimum to run S/C?
  224. ect pwr button
  225. Power steering pump
  226. Thoughts????
  227. Front Brake Upgrade
  228. Mobil 3309 ATF Trans Fluid?
  229. Can this skid plate fit on my 98
  230. 3rd gen hilux surf field unit on ebay
  231. Shortening LC coils
  232. How much is my 4runner worth?
  233. Calling 2002 sport owners...
  234. Is a lift, 285's and towing a bad idea?
  235. how come?
  236. FYI--Parting 97 4Runner
  237. My 97 4runner progress
  238. engine and shotgun shells?
  239. Tundra brake upgrade
  240. 2 tone interior?
  241. tire and regearing
  242. It has begun
  243. Aqquired only TRD S/C unit, What do I need now?
  244. A little update
  245. Strange stalling issue
  246. picture of hilux surf(3rd gen) tire carrier?
  247. 180k Maintenance...How Much Should this Cost Me?
  248. How to Change Powered Antenna?
  249. Pics of the new lift, wheels and tires.
  250. Bypass the OE tranny cooler?
