high idle
Old Oct 28, 2007 | 07:42 PM
BC_4runner's Avatar
high idle
before anyone flames, yes I have searched nobdy seems to have the exact same issue as me
here is the problem truck will idle about 1700 rpm warm or cold sometimes around 1500 when cold. The weird thing is when i coast to a stop the idle will pulse from about 500 to 1200 rpm every second. Thing has a brand new tps and the throttle body looks to be in good shape.
Also the evap vsv and the blue sensor ontop of the evap can are unlpugged (no harness clips) so I dont know which color goes where. This may be the problem but I doubt it because I can take the hoses off and the idle wont change.
The only thing that makes it better is if I unplug the IAC id comes to about 900rpm idle but it throws a CEL and has little power
The engine is from a 1997 4runner 4x4 and the wiring was done by ors. Thing runs like a dream besides the idle issue
Old Oct 29, 2007 | 05:18 AM
xsvtoyz's Avatar
sounds like you answered you own question. IAC
I had the same issue and ended up changing out my IAC and that cured it. I tried cleaning it but it didn't help at all.
Old Oct 29, 2007 | 05:24 AM
MTL_4runner's Avatar
Take off the IAC and clean it properly.
http://www.ultimateyota.com/index.ph...27963#msg27963
Also clean the MAF sensor and double check you don't have any cracked hoses or vacuum leaks.
Old Oct 29, 2007 | 01:08 PM
BC_4runner's Avatar
cleaned the IAC. Still idles kinda weird but its tolerable now
tomczaksdiesel
Jul 26, 2015 10:35 PM
Cbr954ryder
Jul 25, 2015 06:32 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
luckypig44
Jul 19, 2015 11:25 AM
kyletbert
Jul 17, 2015 11:39 AM
