Spark Plug gapping
Old Oct 23, 2007 | 10:06 AM
tigre's Avatar
Spark Plug gapping
I have 2000 4runner with 3.4 engine on it. I am gonna change the spark plugs and i bought some Denso 5062 Copper Spark Plugs. The problem is that i dont know how to properly gap them since they have triple electrodes. So does anyone know how to adjust eh gapping on these or should i just install them how they are. Any help will be appreciated.
here's a pic
Old Oct 23, 2007 | 10:24 AM
Nate08's Avatar
Quite a few spark plugs are already properly gapped out of the box. My new Bosch Platinum Dual Electrodes are already gapped to the right measurment.
Old Oct 23, 2007 | 11:44 AM
Bennito's Avatar
use a wire gauge not a flat blade. still will have problems, but as far as I know, the best way to check. (i say check because the prior comment is correct that often times plugs are pregapped. but i always like to check)
Old Oct 23, 2007 | 11:51 AM
OSU4Runner's Avatar
Most of the triple and quadruple electrode plugs are already gapped. I think you're only suppose to use dual electrodes on the 3.4 though. It says it right on the engine.
Old Oct 23, 2007 | 04:13 PM
urbanj's Avatar
don't count on the plugs coming pre gapped. ALWAYS check them. Just the other day I had a set of plugs for a Ford come and one set was good and for the other bank all the ground straps were bent down. some even bent the platinum center electrode. the packaging looked fine.
You never know who is going to drop your parts. ALWAYS CHECK THEM.
Old Oct 23, 2007 | 04:34 PM
Lone4runner's Avatar
Thought i read somewhere that you are not suppose to gap the double, triple and quadtruple electrodes.
Old Oct 23, 2007 | 04:40 PM
OSU4Runner's Avatar
I know you're not suppose to gap the quadtruple, not sure about the other two
Old Aug 10, 2014 | 06:57 AM
XPY's Avatar
XPY
Gap: 1.1 mm (0.043 in.)
Old Aug 10, 2014 | 05:22 PM
DeathCougar's Avatar
No need for off topic ridiculousness. And don't antagonize someone then report his retort, Arnezie.
XPY Digging up old threads is usually not the best idea, but we appreciate any time we get real tech input into the threads that don't have solutions/answers.
Move along, nothing to see here folks
Old Aug 10, 2014 | 05:30 PM
rworegon's Avatar
An Advanced Search under Tools (this works much better than the Search box on the main page) of: 3.4 spark plug gap
yields this 2010 thread with the requisite gap information for the dual electrode plugs in post 14 and 15:
https://www.yotatech.com/forums/f2/n...gapped-191407/
Old Aug 15, 2014 | 10:15 AM
Potomacduck's Avatar
My factory dual electrode plugs from Toyota are supposedly gapped, but they aren't.
Use a wire gap tool, not a flat blade....and DON'T forget the anti-seize on the threads!
montanatruck
Feb 26, 2017 07:07 AM
raptor510
Feb 17, 2017 07:11 AM
raptor510
Aug 19, 2015 02:15 PM
defrag4
Jul 31, 2015 10:50 AM
cars-guy
Jul 11, 2015 07:51 PM
