How to tell which gearing I have?
Old Oct 15, 2007 | 03:57 PM
jason999's Avatar
1999 SR5, 5 speed, V6 4X4 with the rear diff lock feature. So it appears it could be either 4.10 or 4.30? Is there somewhere on the vehicle that will provide this information?
IIRC, 4.10 is geared "lower" meaning higher rpms at a given speed and better for towing, climbing etc?
Thanks!
Old Oct 15, 2007 | 03:59 PM
Tofer's Avatar
Sponsor
no 4.30 is "lower" gearing.. there is a chart somewhere showing what the gears are based on the axle code in the vin.
a quick 20 second search yielded me this. http://toyota.off-road.com/toyota/ar....jsp?id=274535
Old Oct 15, 2007 | 04:04 PM
jason999's Avatar
Ok thanks, so I had it backwards. So for every rotation of the axle, the engine turns 4.3 times?
Old Oct 15, 2007 | 04:05 PM
GSGALLANT's Avatar
Wow... this has got to be the most covered topic on here. Search, Search, Search...
Click here. This will get you started. Actually, it's all you need.
Old Oct 15, 2007 | 04:07 PM
nix4x4's Avatar
If you search around on richmondgear.com they have a gear ratio/rpm calculator. If you can find out an exact rpm that its running at a given speed ( if you know what your tranny's overdrive gear is, figure out what rpm your running at 70mph) and it will calculate your ring & pinion gear. Its pretty accurate, too. Another route is to look up axle codes and match it up to the sticker in the door jamb.
mskalmus
May 28, 2017 07:51 AM
norcal98
Aug 10, 2015 06:20 AM
wolfpackfan33
Aug 2, 2015 03:36 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
