1996 LC's Installed! Pics coming up!
Old Nov 7, 2007 | 03:54 AM
Nate08's Avatar
Thumbs up 1996 LC's Installed! Pics coming up!
I'll post pics later today. INSTALL NOTE: YOU DO NOT NEED SPRING COMPRESSORS!! SIMPLY UNBOLT THE SHOCKS AT THE BOTTOM, DISCONNECT THE REAR SWAY BAR INSIDE THE WHEEL WELL, DISCONNECT THE BRAKE LINE (DON'T FORGET THE BLEED THE BRAKES ONCE YOU RECONNECT IT), AND PULL THE AXLE DOWN. YOU CAN PUT WEIGHT ON ONE SIDE BY PRESSING DOWN ON THE BRAKE DRUM WITH YOUR FOOT. THE LC SPRINGS WILL SLIDE IN FINE WHEN YOU DO THIS. INSTALL DRIVER SIDE FIRST SINCE IT IS THE LONGEST, THIS MAKES THE PASSENGER SIDE EASIER. Overall I got 3.75" of lift over stock without the conical bumpstops. When we first dropped the jack they were at 4.5" over stock. They settled 3/4" in 1 hour. I found this weird because they are used by 121K. But the ride is unbelievable! It is firmer than stock but yet, its soft. It feels like a pillow, they absorb the bumps sooo nice. It is hard to explain, but it feels MUCH better than the OME 890's. It actually softened the front with how the LC's don't transfer motion to the front, they just soak up the bumps. Haven't had a chance to wheel it because I haven't extended the bumpstops yet. Overall it took 3 hours and 45 minutes. But, we hassled with the panhard bar/fabricating our own drop bracket for 2 hours; which we didn't put to use. So the actual rear-end suspension took 1 hour and 45 minutes. Jerry and I ended up jumping up and down on the towing ball until Jared could time it and throw the bolt through the stock panhard bar and mounting point. My axle is off center by about 1/2". I have just under 1.5" of lift up front. I think I'm going to add 2 topout spacers and extend the bumpstops up front and get limiting straps.
Nate
Old Nov 7, 2007 | 04:09 AM
emptypockets's Avatar
Welcome to the LC club Nate! You'll come to love them even more over time, just as I have. IMO, they're the perfect rear spring, unless you do a lot of heavy towing. You ended up with about the same amount of lift I did with my '95 LC's.
With only 1.5" up front, I'll bet you've got a ton of rake! The rake on my rig is noticable with 2.5". I'm still debating what to do up front, but whatever I end up doing, it will have to wait until spring. Congrats on the LC install, now post up some pics!
Scott
Old Nov 7, 2007 | 04:12 AM
Nate08's Avatar
Scott
Yea, with 265/75/16, im sitting at ~ 39.25" fender to ground. I got quite a bit of rake, but I think 1 inch up front will look perfect!
Old Nov 7, 2007 | 04:27 AM
Another inch up front will put you exactly where I am...noticable rake, but not a dragster either. Are you looking at the front spring route or spacers?
Old Nov 7, 2007 | 04:31 AM
Nate08's Avatar
Thinking of running to SS topout spacers. I'd have to raise my bumpstops up front, and get limiting straps though...
Old Nov 9, 2007 | 03:54 AM
Nate08's Avatar
Okay. I know we all want 1995's. I've found some. I got 4" over stock with 1996's. The coils were 19" and 19.5" with 7.5 and 8 wraps. I'll post my results with the 95's.
Old Nov 9, 2007 | 05:49 AM
MillerPKA's Avatar
go 883s
Old Nov 9, 2007 | 06:04 AM
Nate08's Avatar
Originally Posted by RooRRunner
go 883s
My suspension might as well be concrete.
Old Nov 9, 2007 | 06:13 AM
MillerPKA's Avatar
i don't know why you'd say that, any experience?
Old Nov 9, 2007 | 06:20 AM
Nate08's Avatar
Because many testimonies say 882 are stiff as balls, I assumed 883's would be stiffer because they gave more lift...
Old Nov 9, 2007 | 06:32 AM
Nate08's Avatar
Bad assumption. My appologies.
Old Nov 9, 2007 | 08:23 AM
Skrillah's Avatar
pics!?
Old Nov 9, 2007 | 08:33 AM
Nate08's Avatar
Originally Posted by Skrillah
pics!?
Yea yea yea, I know I know. I've taken em, but I'm at school right now and I don't have my digital camera right now.
Old Nov 9, 2007 | 12:50 PM
Atomic's Avatar
Old Nov 9, 2007 | 03:48 PM
BajaRunner's Avatar
Originally Posted by Atomic
Old Nov 9, 2007 | 05:20 PM
Skrillah's Avatar
Originally Posted by SC4Runner
Old Nov 15, 2007 | 07:44 AM
onesojourner's Avatar
still no pics?
Old Nov 15, 2007 | 08:03 AM
Nate08's Avatar
My apologies. Dad took the camera to Atlanta with him without letting me know. He got back late last night. And I changed to 1995's. I'll post pics today, NO EXCEPTIONS.
Old Nov 15, 2007 | 09:20 AM
BajaRunner's Avatar
You mean no EXCUSES?!
Old Nov 15, 2007 | 04:18 PM
Mr.Dabadina's Avatar
Anyone run with the 94 LC coils?
