Think it's time for new springs?
Hey all, long time since I last posted.
I'm getting tired of the rough ride I've been experiencing in my rig. Just took a look at the rear suspension, and look what I found
I'm guessing that bump stop is way closer than it should be?
Well, I'm not interested in a big lift, so I think I'm gonna just purchase some 99 4wd coils that I can get for like $270 or less. You guys have any other possible solutions to make my runner ride better?
Edit: forgot to mention, I have a 1997 2wd Limited
yeah, it's about an inch higher on the passenger side, I'm guessing b/c the gas tank isn't on that side...I've been wondering why it's been riding like a tank...I think I found the culprit
All I have in the back is a subwoofer cabinet, but I doubt that's the only cause
The 99 4WD springs should work fine.
You think I should spend an extra 80 bucks and get the airlift helper springs in the back? Cause I've done some reading and it seems those rear springs have a tendency to sag. I have a sub cabinet in the back that mabe weighs 75 lbs...and a lot of times have the back loaded up and the back seat full of people...you think that would be a worthwhile investment?
99 4Runner Coils will sag eventually too. Everyone seems to like the Performance Products springs. I have had the Downey 2" spring and they gave the back of my car about a 1/4" rake with stock fronts, looked pretty good and they never saged. I would recomend those but that's all I know besides the taller OME's which are great. Just my opinion, but I would try to stay away from Air bags unless you like a soft ride unloaded but tow heavy loads as well, just because of the extra maintenance with them.
What is your current measurement in the front from fender to ground?
What size tires are you running?
If you're worried about sagging (which you should be with any OEM Toyota springs), then go with some OME 906 coils like I have or the PP springs for the rear. You can go the airbag route but it's a bit of a pain to inflate and deflate all the time unless you have the in-cab adjustment setup. Airbags should be thought of a supplemental (ie towing or really heavy loads) rather than the primary means of support.
'99 coils will take about 100k miles or more before they sag which is quite a long time. I had 100k on my original coils and really very minimal sag at all and here it is next to my '97 which had new '99 coils on it before I sold it.
New '99 coils and shocks
Yeah,I rarely haul too much of anything and the only stuff in the back of mine is a small 10" sub and emergency supplies/off road stuff. I'm an intermediate trail off-roader and the coils are fine but another inch or so would be nice.
My 99 coils I got 100K on them and they look to sit the same height as a co-worker who just got new ones installed in his 97. However when I installed bilsteins the front seemed to sit just a bit higher and this gets aggrevated by loaded the cargo area (why mentioned the airbags for the occassional trip). (The Bils are installed correctly but seems to let the front coild extend more making the front higher. It was easier to put together the front strut with bils compare to the compression on the OEM I took off. Maybe this is for its own thread).
Edit: btw, I noticed my bump stop is a lot smaller than then one in you image
Another solution you may consider is an Air adjust shocks like Gabriel Hi Jackers.
You can get a pair of them from an AutoZone for $62.00
