99 rear coils on 98???
i have a 98 4runner 2wd-the rear coils are way to weak and i am gonna replace them,i have read that 99 4wd rear coils are a little taller and should ride/tow better is this true?not going for lift just to get it from hitting the bumpstops all the time ecspecially when i tow,thanks in advance
Actually more than that. Steve Schaefer has a documented lift at more than 2" over stock from a 2WD with the 99 coils. I 2WD sit lower that the 4WD and 98 4WD are already 1" shorter than 99 4WD. Expect approximately 2-2.25" of lift with them suckers.
You'll love 99' coils. I've towed some decent weight with mine and never felt it bottom out. Consider buying the "SYSTEM 3.0" kit... http://www.sonoransteel.com/store_co..._liftkits.html
Not all '99 coils are the taller variety so you have to be sure what you get. My Highlander sits 2" taller than my mom's '99 Limited;1" is attributed to my tires.
Steve Schaefer also states that not all '99s have the "magic" coils. All '99 Highlanders and most of the '00s Highlanders had them but the other models are hit and miss.
the other options are 99 4x4 15rims factory NOT THE HIGH SPRING
99 4x2 15rims .
I have the 99' 4x416" rim part number at home and can post i a day or so. The new springs were $75 from my Toyota dealer and the lifted my 00' 4x4 16"rims 2" in the rear.
that why i said 99'4x4 16"rims factory
99 4x2 15rims .
99 4x2 15rims .
If your '00 was lifted 2" then you probably got one of the first 4Runners with the a set of the '01 short coils which did show up on the later '00 models.
What is your measurement from the middle of the rim to the fenderlip which is a better measurement then the ground to fenderlip since it doesn't have to account for a tire that could be underinflated or overinflated?
center of hub 22" in the rear.
My mom's '99 is a 4wd w/16" rims and has the the 1" shorter coils so it's still not consistent way to determine which coils a Runner has. I'll do some measurements on her's next time I see her truck.
I installed new OEM coils/shocks about 20k miles ago and my measurements are just over 22" in the rear and just under 22" up front. Mine has settled about a 1/4" since the setup was installed.
I would welcome that part number
99 4x2 15rims .
99 4x2 15rims .
I measure the same on the LOW side of my 98 with stock suspension and stock tires (with little tread left) and wheels... I get 35.5" from the ground to the lowest part of the fender on my high side. I wonder what coils I got...
sandyota
Feb 4, 2021 11:16 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
terminator
Jul 27, 2015 07:13 PM
Vargntucson
Jul 4, 2015 12:15 PM
