A little update
Old Oct 12, 2007 | 10:10 PM
wormhole's Avatar
Talking A little update
Well, I made some progress tonight on the elocked rear axle I picked up. I was able to remove both axle shafts after alot of wd40 and some work (going to be sore in the morning). With no problems, except for a rounded off nut that is now stuck in a socket .
Any how I removed all the nuts/washers from around the third member/diff. but I'm unable to remove it. Is there some special way that I'm supposed to remove it that I don't know about?
I was under the asumption that all that needed to be done was to remove the axle shafts and the nuts around the diff. and it should just pull out. Correct me if I'm wrong.
Progress photo (working out of my parents garage since I live in an apartment):
I'm doing all of this to make sure that the gears are okay and to make it light to transport.
Old Oct 12, 2007 | 10:18 PM
toy_tek's Avatar
I used a 5lb hammer to pound a 24" screwdriver between where the 3rd and axle housing meet to break apart the seal. Just work it around evenly.
Old Oct 13, 2007 | 07:44 PM
wormhole's Avatar
Tried that but didn't get to far. I'll need to give that another try.
Old Oct 13, 2007 | 07:51 PM
881stGenRunner's Avatar
when the axle is still on the truck it is easy since you can just put a jack under the pinion and jack up a lil bit and the seal pops easily. I guess just try to spray around the 3rd with something that may eat away the seal and let that soak in
Old Oct 15, 2007 | 08:31 PM
wormhole's Avatar
Worked on again tonight but to no avail (besides a headache). I'm just going leave it and install it as is.
justdifferentials
14
Jun 11, 2017 08:36 PM
dzldust
7
Oct 6, 2015 05:39 AM
sonorn67
Sep 19, 2015 05:39 PM
carid
Vendor Advertising
Sep 10, 2015 06:11 AM
