Power steering pump
Old Oct 15, 2007 | 04:32 AM
RETRO's Avatar
Power steering pump
The past few mornings it has been cool and when I first get in the power steering pump whines for a few miles then clears up..The motor only has 56k on it..I have thought about draining it and replacing with Lucas..So how is the best way to drain it? And any ideas on what may be causing this?Thanks Patrick
Old Oct 15, 2007 | 05:14 AM
MTL_4runner's Avatar
You might have air in the lines or the level of fluid is too low.
Make sure the pump is filled with ATF to the proper level and bleed by moving the sterring wheel lock to lock.
If you want to try the flush......
http://www.ultimateyota.com/index.ph...18599#msg18599
Old Oct 15, 2007 | 05:27 AM
RETRO's Avatar
I checked it it should level full both cold and hot..Will Lucas Power steering fluid be ok for it..
Old Oct 15, 2007 | 05:29 AM
No, ATF only.
How is the fluid color?
You might also do the flush and see if that helps the condition at all.....it doesn't use much fluid to do it.
Old Oct 15, 2007 | 03:11 PM
RETRO's Avatar
if it has ATF in it it's not red..Like a grayish/black color..
Old Oct 15, 2007 | 04:10 PM
yarosig's Avatar
Mine eventually vibrates and whines, I put in Lucas oil stabilizer and it helped.
Old Oct 15, 2007 | 04:11 PM
nix4x4's Avatar
I've never seen ATF in any color other than red. Power steering fluid is sort of gray/black in color, so I'd bet that its got PS fluid in it. Bleed all the fluid and replace it with Toyota ATF
Old Oct 15, 2007 | 04:22 PM
ARB1977's Avatar
Replace it with a good synthetic atf.
Old Oct 15, 2007 | 04:37 PM
RETRO's Avatar
And the best way to bleed the lines out..Is there a drain plug?
Old Oct 15, 2007 | 05:01 PM
urbanj's Avatar
Make sure its full of fluid with the cap off turn the wheel lock to lock a bunch of times holding at lock for a second. if the system was dry previously make sure to check on the level after a turn or two.
Old Oct 15, 2007 | 05:08 PM
thefallman's Avatar
Lucas isnt meant to be used alone only as an addititve.
Old Oct 15, 2007 | 06:13 PM
yarosig's Avatar
I know I just added it to my current fluid.
Old Oct 15, 2007 | 07:56 PM
Are you reading your own thread?
....if so try rereading post #2 for flushing directions.
Old Oct 15, 2007 | 07:57 PM
Yes, that has PS fluid in it and needs to be flushed ASAP with ATF.
Old Oct 16, 2007 | 04:22 AM
RETRO's Avatar
sorry I am so busy I did not pay attention to your post and did not see the link you posted..I will get to that this weekend..I think it is power sterring fluid in there..I've had the truck since feb not sure why it just started doing this..
Doug4320
Mar 24, 2018 10:11 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Jonny246
Jul 12, 2015 04:51 AM
cars-guy
Jul 11, 2015 07:51 PM
jon.r
Jul 11, 2015 03:34 PM
