- Does Yotatech have any interset in a new alternative for trailer light converters?
- bad gas mileage
- 2 bizzare issues (brakes and transmission)
- Code 71 On a fed/Can vehicle?
- Davis unified ignition question
- are all prerunners automatic?
- Tailgate lip protector 03 Taco?
- finally painted my 4runner
- E-Brake help on a 91
- How to replace rear view mirror?
- Help! digital climate control 99 limited
- T-case skid
- 3VZ-E 300Hp gain N/A brainstorm
- Add on Fog Light Problem
- quick hub question '05 Taco
- wanted pic: 3rd gen 4runner w/ eagle 102, weld stonecrusher, xtreme alloy 1059 etc...
- Auto Climate Control Issues...
- Sport Grill Details.
- Another Dyno Run...
- Studless winter tire questions
- Bucket Seats to Bench Seat Swap
- Drivetrain slipping on 94 pickup
- For anyone looking to do the Tacoma Whip mod.
- ATTENTION ALL 3.0 owners!! Explain your likes and dislikes
- Rims don't fit
- 3VZE PCV valve access ?
- 1986 4runner w/ factory sunroof
- TPS Question
- My 96 4r -Back to stock *PICS*
- history info
- firestone alignment: still drifting to the left and alignment numbers
- Antifreeze In Exhaust?
- killed 2nd gen... now 3rd gen potential???
- 92 to 94 engine swap
- Thinking of making a Jeep Renegade style light bar
- Performance Friction Pads -- all open box
- Duplicolor Fabric and Vinyl Spray
- question about bring rear end back to stock
- Tires: If you were to do it all over again...
- 1996 Tacoma check engine light problems
- 89 4runner question.
- 2nd gen hub removal.... help
- 3.0 2nd gen - slip or chatter on acceleration
- Smaller tire benefits on a 2nd gen?
- 1st gen sitting for a few months
- Hood Latch -HELP PLEASe
- '85 4x4 rear brake problems
- True or False? All aftermarket 16" wheels will rub calipers on a 3rd gen 4Runner
- 1993 Pickup - considering sale - extensive upgrades- PLEASE READ AND COMMENT! Thanks!
- OME shocks no lift
- 1983 toyota 4x4 p/u i just found
- 38s on stock IFS!
- Seattle area Auto Body recommendations?
- stuck hub
- Want some tail light guards?
- chevys with orbit eyes?
- what postion is your pitman arm in ?
- 4cyl vs 6cyl transmission ? read please!!!
- new rims
- 3.4 swap
- Calling all EEs or electrical experts....
- valve cover bolts loose
- Opinion Please: Stock 85 Runner to Daily Driver / Snow Climber
- Air Conditioner HELP!!!
- Rear Axle Help
- Exide Orbital battery owner's speak up.....
- 87 Turbo runner, doggy power
- Weird squealing/buzzing noise
- Damn Powersteering pump
- I drained my battery in my 04 Thundra . . .
- Tacoma triva question...
- Missing Person post on AZOD
- BF AT tire size question
- '00 vs. '01
- 87 runner BASIC buildup.... rnd 1.
- Engine braking in the winter
- dash crack help
- Air fuel ratio sensor location
- better then dynamat?
- leafspring help
- New leafs (help)
- Wheel Help
- SUNROOF/MOONROOF ON '98 SR5 4Runner
- 2.7 stall
- Windshield frame rust spot...
- pickup manual hubs
- Best floor mat in Salty Michigan winter
- To all CB radio users!!!
- How much did you pay for your Yellow Optima D34/78 and from where?
- Is this anyone's on here?(2005 Spt. Ed. on Ebay)
- high idle and knocking" sounds like valves"
- New guy
- Does 2000 4Runner V6 need Timing Belt change?
- 87 turbo 4runner help
- Experience/Opinions regarding extended warranty purchase
- Fluctuating heater temp
- Dexron in manual transfer case and 4wd shifting problems?
- Auto Transmission Compatibility?!?
- need new bed
- manul hubs and turning
- 32's - alignment issues
- Need Tranny
- harmonic balancer off
- Anyone in Idaho with a 3rd gen?
- Getting started as a wheeler.
- Got me some 33's too
- Headlight replacement
- shackle flips
- Torsion bars
- WELDER in Virginia Beach/Hampton Roads area?
- where is the fuel pump
- Engine Ticking Revisted - Sound Clips
- 3 questions wire fuse an antenna
- Engine Cleaning!!!
- charlotte area locker install help
- Longest tread life???
- 5/7 MGE AMF into 3VZE
- Climate Control Went Haywire
- Got new tires and wheels. Now I have front end shake
- Ratteling
- ABS speed sensor
- Help with Shot 3.0 litre
- Battery/electricity question
- Symptoms of a bad TPS on a 3.4L?
- 3VZE Idle circuit experts (Toy Master Tech ?)
- How to reset tire inflation sensor
- Help....3rd gen turn signals not working after mod..
- Mounting a Flag on the Roof?
- k&n vs. Snorkel
- Painting fuel rails
- new truck bed
- diesel question
- F/S: K&N air filter
- Camper Shell questions
- High Idle plus throttle cable loose
- clutch problem
- 01 3.4 throttle body question
- HELP !!! Need 3ZV-E air flow sensor info...
- 3.0 oil pan leak
- Machine shop pricing.
- 95-3.0 Head Gasket
- Urgent clutch release bearing Help
- 4X4 question/problem
- Should it stay or should it go, now?
- Battery be OK?
- Pickup vs. T100 ...
- Yet another Ebay chip
- tire vibration
- Anyone ever heard of Borg Warner?
- nokian tires
- 96 tacoma fender flares
- new seats for the taco...what oems fit
- My little brother joined the Yota family!!!
- Finally got 33's
- 3rd gen cooling fan question
- engine strugle
- New 2nd Gen 4Runner Owner
- Will these new bilsteins work with the coilovers?
- Soon to be proud owner of 1992 4Runner!!!
- 1st gen engine swap...
- Almost Dead and need opinions!!!
- your opinions on Iridium Plugs
- Fuel Pump - 1GR-FE 4.0L V6 - what's the psi rating??
- Zerk or not to Zerk
- New tires! *Pics*
- auto tranny not shifting into overdrive
- Cam Problem....3.0 builders please look!
- What are the best SS brake lines?
- Closer 'n Closer...
- Yet another 5VZ swap q.
- Passenger side coolant leak
- Trouble shifting into 2nd...
- 95 4Runner altutude problem
- anybody ever been to or had any experience with maaco?
- Electric Steps are in!
- Stabilizer-cheap!
- Difficult to brake.....
- How much would my TR4 be worth?
- Can you get taller gears for hilux diffs?
- Air Lift (rear bags) w/ in-cab controller installed...
- DS and PS CV axles done ! Thanks all !
- Toyota head gaskets break the laws of physics
- new tacoma questions
- My Master Plan For Modding My 95
- How long to do sparkplugs
- does there exist a "built" 3.4?
- Adding offroad lights what wire?
- Power Steering pump replacement -- QUESTION...
- oil gallery plug??????
- Bad Master Cylinder or something else?
- Questions regarding tire sizes
- Idle Adjustment on 2nd Gen (1994)? Chilton says cannot adjust - computer controlled??
- 4-Runner Rear Window INOP!
- 4Hi and 4Lo problems
- Reinforce/waterproofing door seals?
- Clutch not lasting, Aftermarket Options?
- recomendation for high mileage clutches/assemblies
- Can't get started to time it
- 3rd Gen clunking
- Interior Touch-up
- Help Quick! Cam break-in?
- What general maintenance needs to be done?
- Question - Optima Batteries
- Tire size question
- Cheapest palce to buy tires?
- Did you guys see this?? Goodtimes and Darx at the Offroad Expo
- Three-way switch
- Flooded engine? Don't give up
- Clicking sound on my 22re
- DH Built
- Help me choose please: T-15 or T-17
- 87 4runner , Heater not working
- Standard Hitch Size 3rd gen
- my lovely 22r and it's dying...
- 29's to 31's on 84 4runner
- 3.oL valve cover leaking...
- Braking problem.
- Which spark plugs for 3.0?
- Front tire alignment issue?
- Towing questions
- 89 4x tranny on a 86 4x
- Tires
- New to me 91 4Runner questions
- Great gas mileage
- Drive shaft lubrication on 2wd 3rd gens.
- strong vibration
- New engine for my 91
- 3VZE and 7MGE parts interchange?
- What gears do i have?
- Knock sensor or vacuum leak?
- Good price to set up front and rear ring and pinions?
- Passenger side power window switch problem
- Cleaning parts w/o disassembly: opinions about cleaners/techniques wanted!
- Help w/ maintenance for 3rd gen (98k miles)
- Where can I buy "husky liner" matterial?
- Need part number for 3VZ-E block heater please.
- Where is the powerband on the 3.4?
- Painting my new runner!
- Need help of anyone in houston area who owns/drives 1st gen 22re/22rtec
- i got a windshield crack = (
- I Want An Xrunner
- 3rd Gen Wet Carpet Help
- weird sound
- will a 90 runner int. fit in an 85
- CD code on 99 double din unit ??
- Removing CV axles on 2nd gen..whats the trick ??
- Lots of researching but no opinions found - suspension
- Truck failed smog, need advice
- t-bars down not up.....
- 22r reliablitiy
