1st gen sitting for a few months
Old Oct 20, 2005 | 10:40 AM
Tacoma Dude's Avatar
Hey everyone,
Because I live 75 miles away from work and am commuting by train (3-5 hours of the day on a train or waiting for one) I haven't had much time to do anything but work and sleep. I *might* have time to FINALLY bleed my clutch this weekend. Only problem now is that the truck has been sitting for about 3 months - is there anything I should check up on? I'm most likely going to change my oil...
Old Oct 20, 2005 | 10:54 AM
punkbek3886's Avatar
it might be a good idea to disable your coil (ignition) and crank the engine some to get the oil flowing before you start it.
Old Oct 20, 2005 | 10:59 AM
DudeBud's Avatar
pull the plugs out and crank it over a few times to get oil through the main and rod berrings, put plugs back in and fire it.
Old Oct 20, 2005 | 11:24 AM
Thanks guys - I am concerned about the oil and was wondering what the best way to handle this was
Old Oct 20, 2005 | 11:50 AM
snap-on's Avatar
you still have bat? wouldnt surprise me if it was deadish...
Old Oct 20, 2005 | 01:08 PM
Not sure but I did unhook the terminals about a month ago.
Old Oct 20, 2005 | 01:32 PM
Glenn's Avatar
You should probably kick a tire or two.
Old Oct 20, 2005 | 01:55 PM
hmmm... good point. I haven't checked the tire pressure since I aired up after Big Bear over a year ago!
Old Oct 20, 2005 | 03:17 PM
89macrunner's Avatar
you should also once you get it running maybe run some seafoam through it before you change the oil
it will smooth things out and knock lose any gross buildups
icentropy
Sep 16, 2020 02:47 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
jasonty
41
Dec 23, 2018 01:00 PM
noahstancik
Jul 17, 2015 05:38 PM
coryc85
Jul 6, 2015 04:07 AM
