Dexron in manual transfer case and 4wd shifting problems?
Old 10-18-2005, 07:40 AM
runethechamp's Avatar
When I had my transfer case on my 94 V6 5sp 4runner replaced a couple of weeks ago it seems like the tools at the shop filled it with Dexron. Will this damage the transfer case? I will tell them to change it to the gear oil recommended by Toyota in any case. Also, can this be the reason why I can't shift into 4wd when I am driving now, or is there something else going on in the transfer case?
Old 10-18-2005, 08:18 AM
PirateFins's Avatar
Umm I would say yes. I would not only make them drain, but flush it and refill.
Other reason to DIY if you are able to.
Old 10-18-2005, 10:03 AM
I will make them flush and refill. I seem to remember somebody talking about synchros and how their performance is affected by the oil that's in the transmission and/or transfer case. Can the difference between Dexron and gear oil totally mess up how the synchros work in the transfer case?
Old 10-18-2005, 12:16 PM
OK, after some reading in my repair manual there seems to be some small differences to the transfer case between the AT, the MT and if you have ADD or not. Could it be that they mounted a transfer case from an AT or a non-add vehichle? And is there anyway I can figure this out by serial numbers on the transfer case without picking it apart? Any help/info is appreciated so I have something to put on the table when I complain to the transmission shop.
Old 10-18-2005, 12:40 PM
4Crawler's Avatar
No synchomesh in the t-case, ATF is probably very thin to use in it. Good old 75W90 GL4 or GL5 oil is fine. For the shift on the fly, ADD I assume? If so, check that the shop did not disconnect any of the ADD wiring on the case or at the front axle or the VSVs that switch the front axle in and out.
http://www.off-road.com/toyota/tech/add/index.htm
Old 10-18-2005, 12:53 PM
Thanks for the info. Just to clarify, when I try to shift to 4wd when the car is moving, I just get a nasty grinding sound and I can't get the stick into 4wd. If I stop, it works and I get the 4wd light on.
Old 10-18-2005, 01:04 PM
4Crawler's Avatar
Is it ADD or manual hubs? If ADD, the lube may have something to do with that. There is some sort of synchronizer mechanism for that to spin up the front driveshaft.
Old 10-18-2005, 01:12 PM
I guess you can have both, right? But I have the ADD system with the full-time locking flanges on the wheels. From the repair manual I see that there is some kind of synchro mechanism in there, but that it is slightly different for the different engine/transmission types. There seems to be 2 synchro rings for my transmission, where one of those are missing for the AT and the other one is missing for the non-ADD equipped cars. I will check if the transfer case fluid change will make a difference first.
Old 10-18-2005, 02:07 PM
leebee's Avatar
get your vin from the ownership or front dash if you can make it out and go to 4crwalers site. he has a section to help decode your vin to see exactly what trans you have. my 93 uses atf in the t/case, but most others use gear oil. find out for sure what is supposed to be in there, then get the trans shop to rectify the situation.
lee
Old 10-18-2005, 02:58 PM
lee
Thanks for the tip. I do know what transmission and engine I have and as far as I can see it doesn't tell me anything more than that. Only the transfer case with the AT uses atf, and they share the fluid, right?
Old 10-19-2005, 01:18 PM
leebee's Avatar
no the trans and t/case do not share the fluid, they are separate, sealed units. your trans code should be a340h and use atf. it may take some digging or prodding of the stealer to verify it, once you know, you are good to go.
lee
( hey, blondie!!)
Old 10-19-2005, 08:27 PM
Adam F's Avatar
auto takes atf, manual takes gear oil
auto shares fluid with the trans, manual does not
mskalmus
05-28-2017 07:51 AM
Road Bull
10-10-2015 04:55 PM
Yota.Jay
07-23-2015 08:08 PM
colinmil
07-06-2015 04:03 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: Dexron in manual transfer case and 4wd shifting problems?
