not going in to gear?
Old Oct 11, 2005 | 02:41 PM
runner126's Avatar
I have 94 runner, its been having some trans. problems. In the first few minutes after starting the car (cold)the trans works ok. After it heats up it seems to mess up. After i stop at a red light and i want to put it back into gear it takes "the strength of ten men" to get it into 1st with a nasty pop sound (feels bad). If i put it into reverse first, it makes a gride noise (that you can feel inside) and then i can put it into first and finally start to move. The shifter works fine when the car is off and put it through some gear changes first. but when the car is on, the clutch seems to not be disengaging all the way?. Something still seems to be moving.? Any help is greatly appreciated.
Old Oct 11, 2005 | 03:20 PM
runner126's Avatar
more
also the trans is rough through every gear, really loose feel as well
Old Oct 11, 2005 | 03:21 PM
Localmotion's Avatar
maybe you need a new clutch?
Old Oct 11, 2005 | 09:26 PM
Waterboy's Avatar
You're not the only one.
https://www.yotatech.com/forums/f2/5sp-wont-go-into-gear-28319/
I've just gotten used to it and hardly notice it when it happens anymore.
Old Oct 12, 2005 | 05:36 AM
Adam F's Avatar
Probably the clutch. Mine did simmilar things and turned out there was a broken spring on the clutch disk.
Old Oct 15, 2005 | 05:13 AM
84sr5yoty's Avatar
Time to replace your shifter seat and bushing. Here is the thread that is involved with this.
https://www.yotatech.com/forums/show...t=seat+bushing
Here is the website that explains the replacement proceedure.
http://www.off-road.com/toyota/tech/shifter/index.html
mskalmus
May 28, 2017 07:51 AM
norcal98
Aug 10, 2015 06:20 AM
wolfpackfan33
Aug 2, 2015 03:36 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
