95-3.0 Head Gasket
Old Oct 16, 2005 | 12:27 PM
fritzy's Avatar
95-3.0 Head Gasket
Any advice on getting HG replaced under factory recall?
Old Oct 16, 2005 | 12:32 PM
CoedNaked's Avatar
Good luck with a 95.
Generally speaking the 95's were considered one of the only years where they had the "right" head gasket. My uncle has a 95 pickup with 3.0 and he ran it to 300,000 KM's without any head gasket problems before he decided to rebuild simply because he wanted to keep the truck.
Old Oct 16, 2005 | 12:44 PM
Paul H.'s Avatar
call Toyota up and ask.
Old Oct 16, 2005 | 05:31 PM
gonzo's Avatar
95-3.0 Head Gasket
toyota case line is 1 800 331 4331
V06 Recall
call them and try.
my 95 4runner was done before i bought it . i checked before buying it. so they do cover at least some 95's. good luck.
Old Oct 17, 2005 | 01:46 AM
ThomasJ's Avatar
I have a 95 and it was covered. However, I would spend the extra money and get ARP head studs and have them tourqe them to ARPs specs. And re-tourqe them after a few heat cycles. All head gaskets will have some settling during the first few complete heat cycles. This releases tension on the studs/bolts and that leads to HG failure.
Old Feb 23, 2006 | 12:02 PM
lng24run's Avatar
I had a 95 and just called and I am not covered... bummer
Old Feb 24, 2006 | 07:17 PM
bgibb's Avatar
I had a '95 that wasnt covered either...the early '95 model was but mine was considered a '95.5 where they "fixed" the problem...it will depend on what month your rig was actually made in '95...good luck
kgcwb44
Jan 29, 2023 10:02 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
Sep 4, 2015 09:27 AM
themightykhoner
Aug 11, 2015 07:37 PM
Coreyr384
Jul 10, 2015 11:13 AM
