89 4x tranny on a 86 4x
Old Oct 12, 2005 | 02:22 PM
Toyota 4x's Avatar
As the title says....will it work? Both 5spd.
I've been trying to find a tranny for my DD, but I ether cant find one or cant afford one as I'm a student at SDSU....
I found a guy 20 miles from my house that has a tranny and t-case from an 84 and a 89...says the 89's in better shape but if it wont work I'll go with the 84...
how much work is invovled?
Thank you!
Blair
Old Oct 12, 2005 | 03:14 PM
Flamedx4's Avatar
As long as both are the same engine, yep, no worries.
5 speeds are easy to drop. (careful not to drop it on yourself!)
hint: borrow all the socket extensions you can find - you'll need them to get the upper bolts on the bellhousing...
Old Oct 12, 2005 | 03:56 PM
Toyota 4x's Avatar
Thank You!
I've tried doing research to no alas...
I'm confused about this shifter issue...On some both go to an adapter...on others one to the tranny and one to the transfer...Some wrecking yard guy was talking bout this and I stopped listening....do I need to be carful bout this or was he crazy
thanks again!
Old Oct 12, 2005 | 08:08 PM
Toyota 4x's Avatar
Bump...anyone else...
thanks
Old Oct 13, 2005 | 04:40 AM
Yoda's Avatar
You need to make sure the shifter comes out the same place as the one you have. We had a 85 22r parts truck, and it was different than the 85 22RE we needed a trans for.
Old Oct 13, 2005 | 07:44 AM
Toyota 4x's Avatar
Thats what I'm tryin to figure out...
Supposidly some have a connector or somthin that they both come out of, and some, one come out the tranny, the other the transfer...
Will it matter if I get the tranny and transfer and they are different...what mods are needed...
thanks again
Old Oct 13, 2005 | 08:05 AM
Flamedx4's Avatar
As I said "as long as both engines are the same" you should be fine.
Why go through the expense and trouble to change out the trans and not put the right one in there?
Here's a resource that might help: http://www.4x4wire.com/toyota/faq/parts/
Old Oct 13, 2005 | 08:21 AM
Toyota 4x's Avatar
Ya I know...thank you...did read that over...
Just trying to get some clafification on the top and forward t-case shiftin off the w-56
mine is either a g52 or g54 although I understand they are the same the only diff is one has steel somthin...
just wondering what would happen if I got a top shifitn when mine is forward
ladybugRC
458
Aug 21, 2020 10:41 AM
TheBFA
Feb 15, 2020 06:55 AM
live4soccer7
May 11, 2016 06:52 PM
Davebarbier
Nov 3, 2015 03:28 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
