- Check out these Ebay rigs!
- Eratic idle at start up
- bad heims or bad gears?
- ? About PF 5024 brake pads
- Annoying rattle! driveshaft?? exhaust?? HELP!
- My check engine light came on in my . . .
- "add-a-leafs" fix my sag?
- Supercharger install ?? Richmond VA.
- I want higher wattage headlight bulbs . . .
- 22RE Timing Chain Alignment
- Anybody used a Curt brand tube style receiver hitch?
- Replace both O2 sensors at same time?
- Seafoam Intake Plenum and Injector Cleaning Procedure
- alternator died this morning
- Options for Wiring a Rear Aux. Light??
- Mass Air Flow Mod 1997 4 Runner 3.4
- 4Runner Hood Scoop
- cleaning AFM
- Steering Rebuild
- link to 95 4 runner 4sale
- Hello
- toyota tranny swap
- Piaa Super duper wupers
- Winter Lighting Suggestion/Question
- Electrical problem '96 4Runner SR5 V6. Is the dealer using me?
- Fuel Smell, Drop in MPG, intermitten drop in Power
- Napa 1515 (Wix Filter) Questions
- Pickup buying advice needed
- Bull Bar For A Tacoma
- Quick question for SAW owners
- How crzy/hard would it be...
- question for anyone in the Denver area ...
- What's up with my gas mileage?!?!?
- Santa came early this year...and a few questions!
- Will my 15x10's from my '90 4runner fit my '00 4 runner?
- Prejector headlight question???
- ENGINE SWAP, carbureted Chevy into 1997 4 Runner
- 22RE junkyard alternator?
- weird engine noise
- warn shackle
- newb 4Runner owner Q's
- Projector headlights for 4th gen 4runner
- Rear Wiper Sag?!?!
- Spark Plug are they worth it or dont bother
- MAF ... ? Pictures, Q's...
- Will the ISR Mod work on my 03 Taco?
- I give up, Anyone have an idea?
- Shifter seat rip off
- Custom camper setup
- gettin truck painted.........
- Rough Idle after plug change
- Please tell me if my engines DEAD!
- Gas Mileage 202: Good News for the pedal mashers (long)
- wreked 4 runner
- Distributor Replacement
- quick question on wheel width of 97 runner
- Air Intake Mod, Air Intake Temp Sensor Mod
- 2nd Genner DIY ARB Installers
- 2005 Tacoma Brochure
- BVSV, is this the problem
- Sheared off grease fitting- replacement?
- KC or Hella?
- TRAC OFF, VSC TRAC, ABS lights on
- [FS] Does this belong to anyone here?
- And today started out so good!
- vent visors: "in-channel" or "doube-sided tape"
- Trans fluid line size?
- Do it yourself!
- CV Boot, Amsoil, repair
- See if you can guess...
- DeMello's New SASed Taco
- What to do? Anbody else experience this?
- 4th gen aftermarket filter experience ?
- Someone tried to steal my Catlytic converter
- Flex-a-Lite Fan - Thermostat Switch??
- My Monday morning blues
- opinion on bug guard/hood protector...
- Denso vs NGK
- Canadian 4x4 laws? Would you move?
- I hear noises
- bilsteing shocks
- 22re wierd problem
- Finally Pictures of My Truck!
- Cat-back systems illegal in CA?
- ATTN: Gearheads - Detecting a Vacuum Leak
- Hot starter won't start.
- Will It Be Too Loud? Exhaust For 1997 4 Runner
- hesitation or stumble during acceleration
- Brembo Rotors Cheap
- I'm Tired of Breaking those darn plastic lining clips
- Brakes redone and I have a tip!
- Best Place for a hide-a-key?
- Tuff Trucks TV Show
- First Time Paint Job
- Check Engine light.. duhhhh
- 4Runner Ads I Have Collected! *Pics*
- Why are they rubbing?
- 3.4 liter performance chips?
- newbi with a ? will they fit?
- HELP! Taco Spacer Install
- Who has these car mats?
- Heater. Help!
- Gear Ratio question
- Draw Tite hitch install on 04 Taco
- Rear Heater - 1st Gen
- Towing a vehicle with A/T - a No No??
- 97 Limited Rear End/transmission Issues????
- Unbreakable AutoLock Pro for a 3rd gen 4Runner
- Recall info
- Driver's side door wont unlock
- converting 85 extra cab 2wd to 4wd
- Newbie on board!
- Searching it really works
- U Bolt Size
- HELP!! Supercharger problems!(Gadget??)
- Energy Suspension swaybar bushing??
- Looking for Powder-Coating shop?
- Power Atenna Help
- Off to buy it Monday
- THE "How many miles do you have?" Thread..
- Hella 500s...
- I'm a noob idiot. Please take 5 min for me!
- WAAG Guard and a Body lift
- what would cause the 30A FL AM2 to blow?
- 2nd gen DRL's turn rear lights on also?
- All Range E-locker HELP?
- 2005 Truck of the Year
- new parking brake
- LC80 rear axle swap?
- Help!! Need proper torque specs 3vze
- Drive belt change on a 3.0L V6
- installed new gauge cluster.. problems
- installed my cornfeds today....now.....
- '00-'04 tail light on a '96 Taco?
- 04 won't start
- belt tensioner price?
- Where is my OBDII connector?
- 5 Questions about 85 4 Runner
- Need a couple engine designations
- FSM downloads
- I will own ALLL with THIS turbo!!!
- locking hubs question
- 2003 work on a 98???
- Rear diff problem/question.QUICK HELP NEEDED!
- Stupid Tire question
- Looking at buying a 98 Taco
- TRD Supercharger 2.7 L AND Computer!
- New Tire Recomendations?
- Urgent! Carbuerator ?'s
- '97 4Runner Limited Looking for new seat covers or new seats?
- Cooling System Flush T Kit Install
- No, my truck is not haunted...or...why my stereo comes on when battery disconnected
- Best clutch to get for 94 4Runner
- Dead Runner - sell for parts or sell as-is?
- Which Fuse Is The EFI Fuse?
- Opinions Needed!!!
- Overdue thanks to YotaTech
- Cigarette Lighter wires question...
- buyers remorse/gas mileage
- The better of the bunch
- HELLO EVERYONE, and 3 inch REV TEK question..
- Mikeys Hummer Custom Push Bar
- where to get Wiper arms??
- trying to scam me?? L O N G
- Clear side lights?
- Nice ride!!Diesel too!!
- swapping chrome grille for black...help needed!!
- Where to get washer reservoir w/pumps?
- OEM 4runner Parts List
- Gurgling noise?
- the 500k mile leghend...IS IT TRUE?
- Gonna Line-X the Rig...whatcha think?
- recent pics of forest driving
- Pics Of My Truck
- Smoked Lights?
- New Products - Take a look!
- Hella 500s: Street Legal?
- Think its worth it? 89 pickup...
- Hi Newbie here. Help Stuck Axle Hub on 97 4x4.
- Code 420...My 4runner is a pot head!
- What size Highflow Cat (99 runner)
- starter change
- need help on ordering u joints
- 1988 4runner help
- 1990 3.0 clutch?
- hard to start
- Will 4th Gen rear discs fit a 3rd Gen housing w/ ABS?
- 4th gen IFS experts...
- anyone got TRD ivan stewart rims on their 3rd gen?
- New To Forums and frustrated
- Well I got another deer last night at 50mph.
- nuke disco bushings
- Head bolt size
- going to check out a truck in the east bay
- Best Deal Ever - S/A and Turbo kit
- I broke my intake silencer box. What should I do?
- Stock wheel size..???
- BJ spacers-problem?
- Why is the 22re so good?
- A/T or M/T?
- Is this a good del?
- Idler Arm Questions
- What would it take to make her streetlegal?
- Check out the flex on this Pathy!
- 3rd Gen. Stock Top Plate
- What more can go wrong???
- 3rd Gen 4Runner 4x clarification
- 1992 4Runner needs help with power
- ISR Mod not so easy on a 1st gen V6
- 96-98 Taillights & 96-00 Headlights for sale
- Trailer Brake Jumper Harness 2004 4runner
- STS Turbo Kit
- Thule "Fat Mouth" clamp for 3rd Gen 4Run
- Rough Idle at startup (search didn't help)
- Sister looking for a 4RUNNER..HELP?
- whistling from my deckplate?
- SAS'd 3rd Gen SPORT in VA ??
- knock sensor wire
- where does the 3rd brake light wire run?
- 4th gen... how much diff to level front and rear
- Any idea what brand wheel might be?
- 4th gen ARB bumper
- Can I use ANY parts off a 84 4wd on a 83 2wd?? HELP
- dirt bikes....
- tire size
- dumbest noob coil question ever...
- How often do you change diff & xfer case fluid
- For Those With Coil Spacers and AAL....
- How do I remove 1999 coil packs?
- Did anybody install Auto-Start on the 2004 4Runner?
- TJM or ARB? (already searched)
- what Gen. truck do i have ? 1 2 3 ?
- Engine surging idle to 4k
- 05 Taco TRD Sport vs. Off Road
- Tundra coils & Revtek onto Bilistens 3rd
- Advice on 04 Tacoma
- 7mgte vs 3.4?
- wheels
- Supercharger _blow out_
- Newbie seeking advice on '88 runner 22re rebuild.
- Brakes....
- Buying on eBay???
- converting a Previa to 4wd?
- Need a new 85 ECU
- Weight of an 88 Shortbed single cab 4x4?
- Another Blown axle seal!!
- RANT: Blankity Blank Thieves at Stevens Creek Toyota in San Jose, CA
- Anyone from around Indiana/Ohio area.
- shoot me... I need some help.
- How much will 33's affect my power?
