Energy Suspension swaybar bushing??
Old Nov 13, 2004 | 07:21 PM
photomike72's Avatar
Energy Suspension.
should I get greasable or non-greasable??
Does it matter???
Thanks,
Mike
Old Nov 14, 2004 | 04:04 AM
"Cat-O-Leen"'s Avatar
Mike,
For the fronts, Make sure you measure. They list the fronts at 24mm. Mine was 27mm they did not fit. The 27mm did not fit my stock brackets. The new greaseable brackets did not fit the frame because the mounting holes were offfset on the tabs. The rear is okay. I think they list them at 18mm and they fit the brackets.
Here's a thread:
https://www.yotatech.com/forums/show...hlight=swaybar
Old Nov 14, 2004 | 07:46 AM
interesting.
Why would they be so far off??
Were these the ones specifically for your truck or were they the "Universal Application" bushings?
There's both apparently. I ordered from summit racing the front and rear kits and they had different part no.s for the fronts.
I'll measure and check it out.
Thanks for the heads up.
By the way, what did you end up doing??
Mike
Originally Posted by Cat-O-Leen
Mike,
Here's a thread:
Old Nov 14, 2004 | 05:09 PM
Mike,
They were listed specifically for my 1995 4runner.
I hooked up with "Cebby" (another Mike). I mailed the greasable set of brackets and my stock brackets. Cebby cut the mounting tabs off both brackets. Then, he welded the stock tabs onto the greasable brackets and painted them up. He did a great job. They lined up perfect! I just looked under this weekend and there are no problems. Still holding strong.
Old Nov 14, 2004 | 05:16 PM
Yeah, I'm trying to work something out with him now.
Thanks for the help!!
Mike
Mike,
kawazx636
Oct 6, 2021 03:03 PM
LittleUgly
15
Jan 2, 2020 01:30 PM
live4soccer7
May 11, 2016 06:52 PM
punks_is_4x4
Feb 26, 2016 04:29 PM
ktm192k
Oct 1, 2015 08:47 AM
