How often do you change diff & xfer case fluid
Old Nov 9, 2004 | 05:43 PM
4Runner4Christ's Avatar
I was curious how often you guys change your differential & transfer case fluids? My Chilton book on the Runner only shows Service/Inspect at regular intervals, but never to replace. I changed to Amsoil about 2 years/35,000 miles ago.
Old Nov 9, 2004 | 05:47 PM
ChickenLover's Avatar
I change the fluid in my diffs and TC about every 40-50k. If you are doing deep water crossings you should change your diff fluid more frequently.
Old Nov 9, 2004 | 05:55 PM
User 051420's Avatar
I change mine annualy, around 30k miles.
Old Nov 9, 2004 | 07:30 PM
NorCalVP's Avatar
On my Taco I do it annually in the spring (usually less than 5K miles per year). I know it's overkill but i don't mind spending the extra $10 on gear oil each year.
On the 4Runner i'll do it about every 20-30K (probably 1.5-2 years)
Old Nov 9, 2004 | 07:34 PM
rimpainter.com's Avatar
Yikes! 30K in one year?
I change mine every 20K miles, which equates to about 2 years cause I never drive my rig.
Old Nov 9, 2004 | 07:39 PM
I have put 34k miles on my 4runner since last September. In Cali, I'd ususually run about 3k miles a month.
Old Nov 9, 2004 | 07:59 PM
fiveofeen's Avatar
just did em all with royal purple. looks like the front axle and tranny were never done! prob hit em again in 30k check em every 5k
i gotta say it was an easy job, didn't even have to lift it. my other car its a project just gettin it in the air
Old Nov 9, 2004 | 08:36 PM
KING's Avatar
Three thousand miles a month is a lot of gas money.
Old Nov 9, 2004 | 09:25 PM
toy283's Avatar
I change the rear and tranny/transfer every two years or so. The front can go longer with manual hubs but it's just as easy to do everything all at once.
Old Nov 10, 2004 | 03:21 AM
4RunnerFever's Avatar
Can't he go longer with synthetic. I think the Toyota recommendation is every 30k
Old Nov 10, 2004 | 05:00 AM
rwmorrisonjr's Avatar
From: Home: Aurora, CO; Work: The People's Republic of Denver
I do mine every 30k along with the major servicing.
Old Nov 29, 2004 | 06:07 PM
2000t4r's Avatar
What fluid are you guys using? Is there anything better than OEM?
Old Nov 29, 2004 | 06:17 PM
Amsoil!!
Redline Heavy Shockproof is good too.
Old Nov 29, 2004 | 06:38 PM
Amsoil here too. Actually, I will be going back to Amsoil because my diff swap forced me to go to regular (just for now). Otherwise Amsoil it is!
Old Nov 29, 2004 | 07:06 PM
azrain's Avatar
Every 10K (every three oil changes) or right after a big wheeling trip (so not that many times lately ) and all dino lubricants. For an extra $30.00, what does it hurt?
Oh yeah, pet peeve; there is no need to crank down on those drain and fill plugs, that is why they have gaskets. Plus the fact that there are some aluminum housings involved...
Mike
Old Nov 29, 2004 | 07:34 PM
Yoda's Avatar
Mine get "milky" about once a year, so they get dumped. Gotta do those extended breathers on the cruiser!
Old Nov 30, 2004 | 12:27 PM
Flamedx4's Avatar
I, err... ummm, .... yeah... soon!
Old Nov 30, 2004 | 01:03 PM
X-AWDriver's Avatar
Every 30k here and since I just got the '99 I'm gonna do it soon.
Old Nov 30, 2004 | 01:18 PM
bulldog-yota's Avatar
Changed my diffs and transfer to mobil1 syn at 20k, will probably check again at 40k and then do at 60k.
Tranny did a flush at 20k, with Toyota ATF type IV. Will probably check at 40k again. Hope I can go to AMsoil ATF at 60K or so. IS AMsoil ATF replacement for Toy ATF Type IV on the 5speed auto?
Old Dec 11, 2005 | 03:50 PM
cruzin1a's Avatar
I have a 5VZ-FE 3.4 liter in a 99 limited 4runner and I am trying to find a good correct oil for the differentials, would the Heavy Shockproof be the one I should use for my vehicle?
