Napa 1515 (Wix Filter) Questions
Old Nov 16, 2004 | 05:02 PM
automechanicaddictio's Avatar
My buddy has a 1987 Toyota 4x4 X-Tra cab truck,with the 4 cyl 22re motor,and i do his oil & filter changes,we would like to run 5 - 6k oil change intervals with filter,and we were curious if a napa 1515 (ph8a orange can o death fram equivalant) filter would fit without issues,there is plenty of clearance from when i last looked and put the standard ph3614 fram filter equivalant on from napa (a napa gold),and we would like a quart or so extra oil capacity,and somemore filtration ability,it looks that it will fit without leaks. Anyone try this?,please advise. Thanks much
P.S - Castrol syntec 10w30 oil is what we use
Peter Bellantoni
Old Nov 16, 2004 | 05:33 PM
lbb-1's Avatar
http://minimopar.knizefamily.net/oilfilters.html
Old Nov 16, 2004 | 06:28 PM
kyle_22r's Avatar
1515 is a diesel filter, but it'll work great(just more holding capacity). i'd buy them if they ever had them in stock at the local parts place that sells wix filters
Old Jan 10, 2005 | 06:00 PM
Yamaha+Toyota=Fun's Avatar
Digging this thread up......
Do the WIX 1515 have an anti-drainback valve?
Old Jan 10, 2005 | 06:09 PM
terryjmatthew's Avatar
Kyle,
Try your local Carquest store. Their # is 81515 (I think they just add an "8" to the wix number)
BTW, Wix makes the CQ and NAPA premium filters.
Old Jan 10, 2005 | 06:12 PM
TACOMANATOR's Avatar
Another decent filter is the Carquest premium filter. I have seen them cut in half at the store beside other filters like the Fram. They have metal endcaps, anti drainback valve, and bypass valve. Around $5. If you are going to spend that much money on oil I would go with a real synthetic like Mobil 1, Amsoil, Royal Purple. Syntec is just a super refined dino oil.
Old Jan 10, 2005 | 06:13 PM
jimbo74's Avatar
the napa one is fine... i run napa's filters in mine or the motorcraft ford ones i get at walmart.... the fram sized ph8a fits in my 4x2 22r engine with no problems
mine is a ford motorsport filter....
Old Jan 10, 2005 | 08:50 PM
kyle_22r's Avatar
napa/carquest ARE wix filters
i noticed that the diesel filter seems to be a "common" one, as autozone has the model in stock in it's own cheapo brand(valucraft). they only have about 10 different numbers at our store, and guess what? the toyota diesel one is in there. i might have to do some cross-referencing and find out what exactly is interchangeable and common
Old Jan 10, 2005 | 08:59 PM
jimbo74's Avatar
the fram ph3614 is what most toyota trucks use... however a ph3600 (same diamter but about twice as long) also fits (mainly used on v6 fords mustangs, rangers and others) as do the ph8a (wider and bigger, most commonly found on ford v8s and ford trucks, mustangs use them)
Old Jan 10, 2005 | 09:03 PM
Yoda's Avatar
Yes, the NAPA gold 1515 fits (it's on my son's 22re now) and yes it has an anti-drain valve
Old Jan 10, 2005 | 09:05 PM
jimbo74's Avatar
most filters made noadays have antidrainback valves... i jsut personally think frams suck.... wix/dana/napa ore cool...... they use better media and stronger construction.....
Old Jan 10, 2005 | 09:44 PM
kyle_22r's Avatar
fram filters are junk...when i bought my truck it'd take about 6 or 7 seconds to register oil pressure because the huge fram filter the previous owner installed took forever to fill up with oil...no drainback valve or anything there it seemed.
i figure $2 more every few months is worth it, compared to rebuilding an engine...
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
Toyvana
Jul 29, 2015 10:47 PM
calderp
Jul 27, 2015 09:58 AM
nonstop
Jul 24, 2015 06:29 PM
jjrbus
Jul 23, 2015 05:05 PM
