installed new gauge cluster.. problems
Old Nov 13, 2004 | 12:36 PM
hubsj's Avatar
Angry installed new gauge cluster.. problems
Installed a new used cluster, swapped out the speedometer box with old so the miles would be accurate, however, the speedometer does not work correctly now.. inaccurate readings and fails to go back down. Suggestions?
hubsj's Avatar
sorry... 88 4runner.
Old Nov 14, 2004 | 06:28 AM
EnolaGaia's Avatar
OK... You've got an '88 4R. What was it that the new cluster came out of?
If it were a later (electronic) speedo, I'd start by guessing your replacement came from a vehicle with a different # of cylinders. Since the '88 is mechanical, I'm guessing either a messed-up cable linkage or damage to the new cluster???... If the 'new' cluster is for a different application, maybe your swapped (original) speedo unit doesn't work with it?....
Jdgarrison
Oct 1, 2015 05:22 PM
gary4runner
Sep 24, 2015 12:53 AM
rushw
Jul 18, 2015 01:46 PM
Tyler Cunningham
Jul 11, 2015 10:18 AM
Poncho0206
Jul 10, 2015 06:21 PM
