- fixin the rake.
- Engine hesitates under boost, but AFR is fine?
- '02 Runner blowing hot air into cabin??
- OME N86 Shocks - Broken off upper studs?
- Pictures of my 4runner progress
- How to make a Pre-Runner 4WD Worthy (Not Rock Crawling Style)
- CV Axle movement in Diff housing (normal?)
- Found E-Locker, looks rough. Need advice
- Help...2000 Auto Climate Control Troubles
- Taco-runner
- Under-Hood Fuse Block - Wiring Upgrade Q
- OEM Knock Sensor Differences?
- Back from the dark side...with a 2002 4Runner
- Crank Position Sensor/Gear Pictures.
- Advice on 1/4" Wheel spacer for OEM 5 star wheels
- Issue 2 - Auto Tranny doesn't hold vehicle
- Issue 1 - suspension rattle
- need help fast!!
- Alternator Question
- engine swap
- engine swap
- Flat Towing
- New Bilstein 5100 Fronts (set them to Stock Height or up 1" or up to a 2.5" Lift
- Fix it or not?
- 97 4Runner I4 Rough cold start
- 90k mile maintenance before I buy.....
- Clunk in front driver side and slows the truck down
- Brakes done!
- Repainting an axle
- Cruiser springs compatible w/3rd gen?
- Roof Rack
- URD 7th Injector Kit Install
- Spring install help.
- Utah install shop?
- Ac Compressor removal
- 97 4runner suspensions OME or ?
- Pcv Catch Can
- Oh crap! !" BL now leaking T-case
- rack cross bar light clamps???
- Jackpot !!
- 285-75 R 16's on 16x7 rims?
- Are there any .5" rear spacer lifts? The smallest I have found is 1" (yes I searched)
- Starter Issues Need Help ASAP!!
- Cleaning IACV
- Anyone know where the "vacuum switch solenoid" is it?
- Auto and 5spd swap...Xcase Question...
- Rancho Quick Lift
- 2000 limited 4runner AC controls Pulsing?
- HUGE range of estimates - timing belt change
- 285 fit
- Throttle body removal
- 2002 3rd Gen 4Runner - fog lights installed?
- Power Steering pump leaking?
- Keyless remote not wanting to work right
- Just did a compression test, what is the 5VZ 3.4 supposed to get?
- whats wrong with this truck
- 99 and up headlights fit in 98??????
- Satoshi grille mod
- Rear Suspension Safety Recall Follow-up
- Naming Your 4Runner...
- Can I put a 99+ front bumper on my 97?
- What ia a hoop, in terms of a bumper?
- Low idle when engine warm
- Tail light question
- TRD Tundra setup complete, need help out back
- '96-'00 5-Speed Wanted-Colorado
- Tacoma Skid Plate on 96-98 4Runner
- 1998 4Runner rear door vent window
- Had my fender flares painted.
- LC Coils & Swaybar Links
- slow to start
- help -ebrake seized at drum 2000 4runner
- anyone else get a wierd smell when using A/C on really hot days?
- Cleaning your IAC valve
- ??? about wheel seals
- Rocky Top Runner
- AC condenser
- Highway Milage.
- Another happy customer (URD Crankpulley Installed) and custom endlinks
- new rims for factory tire question
- Steering Rack Bushing.
- 1st gen supercharger
- Engine Cleaning
- Dynamic tensioner question
- I think I have to sell my 4Runner
- help, I need a throttle cable bracket for supercharger install
- Gearing question
- Are Tube Doors Available for 3rd Gen 4Runners?
- Anyone with pics of Tundra coils/OME w/ 265/75/16?
- Importing 3rd gen hilux surf from Japan
- What's Up!
- Bad gas mileage
- Looking for 99 springs
- Ideas on getting shocks out?
- Any Surfers out there??
- 90,000 service 2002 Sport (Advice or Recommendations)
- Do they make an Inclinometer for 3rd gen 4Runners
- Toytec/OME installation - weird UCA issue
- part number on the 7th injector gasket??
- 2001 Rear diff breather part number - discontinued??
- Coin tray issue
- New '02 Owner, Questions!
- autotranny filter removal on a 98runner
- Oil pressure & Trans Oil Temp Install ??
- Any toyota parts guys on here
- Leaking something in the back (fuel or oil?)
- Will be purchasing 3rd Gen 4runner in the near future... I have a few questions!!!
- Both SR5 and Limited Badges?
- Pro-Comp Leafs?
- Reverse Gauge Install on Gen 3
- Rake or No Rake, that is the question.
- starter clicking but not starting
- Plug broke-off in head, now what??
- Center Caps
- Bleeding the Brakes
- Yeah, I'm a noob still. Tire question
- Tacoma Caliper Rebuild
- TerraGrapplers 265/75/16 on! PICS>
- Triple gauge pod!
- Power Seat - Broken
- 98 4runner won't start!
- redying interior, coloring the leather (black)
- Loose Door Panels in 02 4Runner
- Hydro Lock--Scary Exper....
- Tundra Coils Yielded Just Under ONE Inch?
- More wheel painting (Pics)
- Well I do need a lift. *TRAIL PICS*
- Pro Comp poly lifts??
- Parking Lamp Wire?
- shifting and starting issues
- FMU Field Monitor Unit Install in Gen 3
- Land Rover salesman's smug smirk wiped off via 02 4Runner ;o)
- Love my new install (PICS)
- Quiet Muffler (not stock)
- Beware! Make sure to check your sparkplugs!!
- transmission filter/ dipstick FIASCO.
- Checkout my Hilux Surf
- I have a bird in my 4runner.
- 1999 Toyota 4 Runner Steering Rack Question
- Read diff breather - what to inspect?
- What type of grease
- 99 4Runner Fog Lights
- 2" body lift installed!
- HELP! Traded in '99 4runner for a 04Tacoma!
- 3rd gen 4runner - OME 3" kit - will 305's fit?
- Hmmm...
- Oil pressure & Transmission Oil Temp Install ??
- Flex Pics...
- Another FMU (Field Unit Monitor) mod
- '02 Tacoma 3vzre no compression!?
- Flush engine with ATF; good idea?
- Spark Plug Wire Diagram
- Anybody have pics of 3.4L Mounted to Engine Stand?
- Last photo of my 4Runner
- 2004 Tacoma REAR shock install q's...
- Bad gas mileage (bad catalytic converter?) Help!!
- What's involved in 3.4 engine R&R?
- Strut mount squeak
- Brakes and Rotors
- VORTEX Muffler Sound clip...
- Duralast Gold Batteries?
- Sweet rigs :)
- shock/strut package suggestions?
- 96 Tacoma 3.4 5VZE Head Gasket Installation - need help
- 96 Tacoma 3.4 5VZE Head Gasket Installation?
- Key remote not working
- How do you change the CV joint???
- need some help.
- New Hood
- FMU Temp Sensor
- Need a 2nd Key for 99 4Runner
- I'm Looking for a 3rd gen part number?
- New look to my 4Runner!!
- need quick answer on driveshaft swapability
- Pics of 3rd Gen with PP 1" & 265/75/16 on Stock Wheels
- pictures
- 3rd Gen 4Runner Yotatech
- Tundra/OME Lift Going on Tomorrow...Pics*
- Whole buncha Mod's
- Just installed TJM
- RS3200plus alarm and rear door locks on 3rd gen 4runner
- Vortex vs. Flowmaster 40 Series.
- Dash Lights Blinking W/ Turn Signals?
- Manual hubs from a 92 fit a 2000? (I searched)
- Hilux w/ 3" BL & 6.5" SL
- Need help replacing Pass. side front window
- Bad Rear Suspension???
- Replacing Corner Light Bulb
- bulb size
- will 04 Tacoma 4x4, stock 16" wheel---fit 97 4x4 with no problems?
- Got new TRD coils for the 4Runner?
- Finally got it together:Homegrown 7.1
- Rear Wiper Part Needed
- FEELER: 1999 Toyota 4Runner Highlander/Sport V6 4x4 Auto
- Need Quick Advice On Pricing My Wheels Plz!
- Smellin Antifreeze
- Another starter question .
- Loud window (when rolling down and up)
- Rear Spoiler/Fin Removal Question
- Rear Cargo A/C?
- Nice X-Runner
- To Sell or Part out my runner... that is the question
- Tachometer not reading right
- The right tranny cooler location??
- 3.4 heated up, now blow head gasket?
- Stuff For My Tacoma
- Flares gone black, woo hoo!
- 97 SR5, 2.7 L ISR questions and Grey Wire mod question
- OME 882, Tundra coils comparison pic?
- Interior air filter on a 2001 and the fan cleaning
- Lotek Gauge pods Question
- Dash Clock Problems
- [Question] Front Stabilizer End Link Bushings
- Fuel line wire help
- Owner's manual
- Couple pics of my runner
- Vibration/Bouncing/Jerking while at a a crawl
- Revtek out - top outs in...
- Starter problem
- springs versus top out spacers
- How do I wire (3) lights?
- 99 Runner brakes and battery info needed.
- problems with dccontrols.com
- Shocks and Brembo's - Check
- Gift from the brown santa
- Drive Belts 5VZFE
- Tjm
- leaky oil seal help.
- Suggestions on suspension setups for stock height
- how did he disable my power antenna
- Looking for the link?
- Frame prep for paint
- Directions to replace an air/fuel sensor
- Warning:4Runner fog lights from Perf. Prod.
- 1 1/2"front tow bar hook ups?
- 3rd gen. 3rd row options MONTERO?
- Stupid Steering Wheel Shake
- JC Whitney leafs
- Got Grille Guard?
- Nicked the end of rear axle while changing seal
- Dropping my tire size
- Does something look wrong here
- 97 tacoma question
- Replacing Cat on 02 Cali Model *SEARCHED*
- Used Tundra coils for 4runner lift, how many miles is too many miles?
- Engine vibrates in gear when stopped
- Refinishing the wheel wells on a 3rd gen runner.
- Mild lift and new rubber on my gen3 4x4
- Suspension Woes, evil ball joints
